elixir20 1 #1 Posted January 30, 2011 Hi guys, I have a '79 C-161 twin with the 16hp briggs model 401417, type 0130 01. Does anyone know if model 401117 type 0010 01 would be a bolt on replacement? It apparently came off of a water pump...I am thinking of purchasing this if it is the same unit. I found the model I have on PartsTree, but they do not recognize the 401117 model. Thanks. Share this post Link to post Share on other sites
sgtsampay 117 #2 Posted January 31, 2011 I think the model number may be 401417-0010-01. If this helps anyone. Share this post Link to post Share on other sites
KB9LOR 4 #3 Posted January 31, 2011 Don't know if it is a direct bolt-on or not, make sure the crank(where the bell clutch goes) is the same size as yours, and the bolt pattern are the same, if so it wshould work. Share this post Link to post Share on other sites
sgtsampay 117 #4 Posted January 31, 2011 I can measure the bolt pattern tomorrow and post that info up.. Good idea KB. I can also get the diameter of the crank but I'm fairly sure its 1in. Share this post Link to post Share on other sites
Sparky-(Admin) 23,987 #5 Posted January 31, 2011 Was it a pull start water pump? You'll need to swap a bunch of parts off yours to get it to be an electric start unit with a charging system if it was a pull start. Mike....... Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #6 Posted January 31, 2011 If you know both model & type numbers are accurate, you can compare part numbers at one of the many websites. (like PartsTree) Crankshafts used in pump applications often have a threaded end to attach the impeller. Share this post Link to post Share on other sites
