JC 1965 1,534 #1 Posted January 26, 2011 The oil pan gasket on my 1979 C81 is leaking. Do you recommend using a gasket sealer? If so, what kind? Any recommendations would be appreciated! This is my first post, I have received a lot of information from this forum, and it is much appreciated. Share this post Link to post Share on other sites
just me 0 #2 Posted January 26, 2011 I'm guessing this is a Kohler 8hp. You can get a gasget for this. And it is really esey to change, by removing the engine and then sepertaing the pan from the bottom and relpaceing gasget Share this post Link to post Share on other sites
rmaynard 16,696 #3 Posted January 26, 2011 Remove the pan, clean both surfaces and install a new gasket. No need for sealer. Torque to the correct specs. Bob Share this post Link to post Share on other sites
JC 1965 1,534 #4 Posted January 26, 2011 Yes, it is a kholer 8HP. Thanks for the help! I have already purchased the gasket, I just didn't know if i needed to use a sealer or not! I knew i could find an answer here! thanks again. :banghead: Share this post Link to post Share on other sites
just me 0 #5 Posted January 26, 2011 no sealer needed but you can add a small dab in two or three places to hold in place while putting back in place Share this post Link to post Share on other sites
VinsRJ 723 #6 Posted January 26, 2011 I personally like to give both surfaces (block & pan) a very light coat of sealer. Torque to spec and let cure for 12-24 hours prior to filling with oil and running. Share this post Link to post Share on other sites
just me 0 #7 Posted January 26, 2011 in my opinion not that it matters much but if you apply sealer to both sides of the gasket especial if it cork or paper then you defeat the purpose of the gasket. For example, once the oil starts to be absorbed by the gasket then it gasket starts to swell which in turn seals even more. If there is a RTV or sealer on the gasket then it does not get to do this and you rely solely on the RTV to seal it. Share this post Link to post Share on other sites
JC 1965 1,534 #8 Posted January 26, 2011 I have "permatex super 300 form-A-gasket sealant". If I decide to use a sealer, would this one be okay to use? thanks for your help! :banghead: Share this post Link to post Share on other sites
