Operator 7 #1 Posted January 25, 2011 I have a dozer/snow blade for my D-series tractors, that is suppose to fit the C-195 too right? Same type of rear latch hitch system right? Now if that C-195 has the rear pto pulley stuff will it still work? And if the C doesn't have the rear latch is that the same as my D's? Randy Share this post Link to post Share on other sites
refracman 166 #2 Posted January 25, 2011 You will have to remove the pulley guide that bolts to the rearend. The rear attachmatic you will need is GT14,C195, D160/180/200. O and yup its the same blade as the D Share this post Link to post Share on other sites
Operator 7 #3 Posted January 26, 2011 OK thanks Steve. I kind of figured that I'd have to remove pulley thing. I have a rear hich from a D-something and just held that up in back but it seemed to wide for the bolts on C. Can that hitch stay on or does it have to come off each time for pulley thing? Randy Share this post Link to post Share on other sites
refracman 166 #4 Posted January 26, 2011 Randy, I was lead to believe they were the same width, but hey what do I know as I only had one D and it didnt stick around for very long. At any rate the brackets are the same just need to modify the spacer bar to fit. And yup the plow bracket needs to come off if you want to install the pto pulley assembly. Share this post Link to post Share on other sites
