rockbuilt 7 #1 Posted January 23, 2011 My C195 is pumping smoke and oil into the carb through the pollution tube I am told it needs new rings. I have tried to adjust the carb and it runs well for a while and no smoke from the exhaust, but the oil in the carb is choking out the engine. I can get it to run like a scared rabbit with the air filter off but I cant get it to stop spewing oil into the air cleaner any advice would be great Share this post Link to post Share on other sites
Roger from southern Iowa 1 #2 Posted January 23, 2011 Mine did the same thing until I checked the crank case vent assembly and reassembled it correctly. I suggest you check that before anything else. Just my experience. Share this post Link to post Share on other sites
rockbuilt 7 #3 Posted January 23, 2011 I knew it was a good idea asking here before jumping into something big Thank You Redsquare for my next question, does anyone have or know were I can get the manual for the KT19 I have the owners manual for the tractor but not the engine :thumbs: 1 Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #4 Posted January 23, 2011 does anyone have or know were I can get the manual for the KT19 http://www.asberry.net/files/TP-2043-A.pdf Share this post Link to post Share on other sites
bobert94 38 #5 Posted January 23, 2011 It could be the umbrella valve in the breather assembly. There made of rubber and over the coarse of nearly 30 years they get brittle and the stem falls off. The part is no longer avail. from kohler. But there is a replacement breather assembly part # 52-03502-s costs around 14.00$ :banghead: Share this post Link to post Share on other sites
