dadstractor1 5 #1 Posted January 19, 2011 :banghead: c141 will not crank start or run because pto switch is bad got snow coning this is my blower tractor need easy way to bypass switch to many wires dadstractor Share this post Link to post Share on other sites
TT-(Moderator) 1,170 #2 Posted January 19, 2011 Did you try hooking the same colored wires together? Share this post Link to post Share on other sites
dadstractor1 5 #3 Posted January 19, 2011 i think i have tried every combination there are several blacks and two reds , Share this post Link to post Share on other sites
rmaynard 17,170 #4 Posted January 19, 2011 Should be two red wires coming into the switch, and two other wires, probably black. Jumper the red wires. The other two wires are part of the seat (dead man) switch circuit. If the whole switch is bad, you won't have any +12v to the coil either. So you may have to jumper them also. But the two wires that are in the solenoid circuit should be red. Share this post Link to post Share on other sites
rmaynard 17,170 #5 Posted January 19, 2011 Here's the wiring diagram: Share this post Link to post Share on other sites
420lse 18 #6 Posted January 19, 2011 My C145 did that. Ended up being the seat swich. Good luck with it. Share this post Link to post Share on other sites
TT-(Moderator) 1,170 #7 Posted January 19, 2011 Did you check to see if there's power TO the ignition switch? :banghead: Share this post Link to post Share on other sites
dadstractor1 5 #8 Posted January 19, 2011 seat switch and trans switch was bypassed had it cranking but no fire thanks for the help and wiring ,diagram. Suppose to get 5 to 7 inches tomarrow ,dadstractor Share this post Link to post Share on other sites
