lincolnpower38 0 #1 Posted January 17, 2011 Ok so I have a snow cab for my 416-H but I have no instructions or lititure on it and I have no idea where the mounts need to go on the foot pans or the rear finder mount do i need to drill in the rear fender????? thanks Share this post Link to post Share on other sites
AMC RULES 36,956 #2 Posted January 17, 2011 They say a pict is worth a thousand words. Maybe this will help? Share this post Link to post Share on other sites
MikesRJ 552 #3 Posted January 17, 2011 How about a set of similar instructions: http://www.mywheelhorse.com/graphics/file/.../AlliedCabs.pdf http://www.mywheelhorse.com/graphics/file/..._500_Series.pdf Share this post Link to post Share on other sites
lincolnpower38 0 #4 Posted January 17, 2011 Yes those help a lot thank you. Do you have a pic of the back? Thanks Share this post Link to post Share on other sites
AMC RULES 36,956 #5 Posted January 17, 2011 Best I can do for you now buddy. Share this post Link to post Share on other sites
mr.pipes 4 #6 Posted January 17, 2011 I have a PDF Manual for Original Cab Co. for a WH if you want I can email to you. I checked after I posted and it is the same as the second link MikesRJ Posted. It said 500 so that threw me off but it if for 300,400,500 series. Share this post Link to post Share on other sites
lincolnpower38 0 #7 Posted January 17, 2011 For some reason I can not open up the 500 page which is the one need Thanks guys for your help!! The pics defiantly help you must have added extra bars for the rear so you didn't have to drill holes?? Share this post Link to post Share on other sites
AMC RULES 36,956 #8 Posted January 17, 2011 I'll get you a better pict tomorrow of the rear frame mount. :banghead: Share this post Link to post Share on other sites
mr.pipes 4 #9 Posted January 17, 2011 For some reason I can not open up the 500 page which is the one need Thanks guys for your help!! The pics defiantly help you must have added extra bars for the rear so you didn't have to drill holes?? If you give me your email address I will send you the manual. I don't know if you can add attachments through the RedSquare email. The 500 manual doesn't show the horizontal bar AMC has on his. Share this post Link to post Share on other sites
mr.pipes 4 #10 Posted January 17, 2011 Manual sent. Good luck. Share this post Link to post Share on other sites
AMC RULES 36,956 #11 Posted January 17, 2011 The bottom rear panel of my cab has both snaps and ties that attach it to that bar across the back. Once it's all snapped and tied up, push the bar in close to the rear fender pan. Helps to keep the wind out and make it nice and cozy in there. :banghead: Share this post Link to post Share on other sites
Operator 7 #12 Posted January 18, 2011 And may I make another suggestion? Put Duct tape under those two pieces under the seat, the fender pan will get marked up otherwise. Randy Share this post Link to post Share on other sites
