Brrly1 1,146 #26 Posted January 14, 2011 27 x 8.50 x 15's See Ya, Bye Burly :thumbs: Share this post Link to post Share on other sites
fireman 1,022 #27 Posted January 14, 2011 Good luck finding the correct rear tires. The size has been discontinued by all the manufactures that I looked at. I was lucky and found a brand new pair mounted on brand new original rims for $200. Again a big thanks to Mike'sRJ for picking them up and bringing to the show last year for me :banghead: Share this post Link to post Share on other sites
truckin88 104 #28 Posted January 14, 2011 I have a question, can these be worked...I work my machines, and have stuck to the standard C, 300, 400, 500 machines. I haven't found the right D. These Super C's look so bad a$$, but scare me in the sense that if you brake something how hard is it to find a part to fix it or how expensive is it to repair. Do the KT-19's have the same rep and issues as KT-17's? Thanks for the education, Will Share this post Link to post Share on other sites
stevebo-(Moderator) 8,649 #29 Posted January 14, 2011 Will, I think you will find that most guys will tell you this is the wrong tractor for you to "work" due to the low number of them around and they are collector machines. I plan on using mine to mow (only on Sundays ). I can tell you they were made to be workers !! The KT19 did not have the same issues as the early 17's. Share this post Link to post Share on other sites
defed 0 #30 Posted January 14, 2011 The KT19 did not have the same issues as the early 17's. i think that the KT19 came in a version I and II, same as the KT17, with the same issues in the version I. Share this post Link to post Share on other sites
CTPATRIOT 12 #31 Posted January 14, 2011 Carlisle makes 29x12.50x15 Tru Powers,anybody ever try them? Share this post Link to post Share on other sites
