case442 132 #1 Posted January 9, 2011 Hi All, I would like to install a clevis hitch on my 1988 312-8. Will this type of hitch work on my tractor, and is there a lift rod required to operate this hitch? Also what would this rod attach to on the tractor? Thank you, Mike Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #2 Posted January 9, 2011 85518 should be the newest version of the clevis hitch kit. Last time I checked, the complete kit was around $300. Link to parts drawing The front of the cable attaches to the bottom arm on the implement lift shaft. Share this post Link to post Share on other sites
case442 132 #3 Posted January 9, 2011 TT Thank you very much, I see that there is much more required than just the hitch mount itself, may just stick with using the three point on the 2418. Thanks again, Mike Share this post Link to post Share on other sites
