Countdown To Christmas!
iicap
Fuel line question
iicap
Hi, can someone tell me the factory, correct, way to route the fuel line on a 1981 C-81 after it goes thru the support near the trans/axel dipstik tube to where it come out under the dash tower at the frame. I'm in that area now doing lift linkage repair and want to route the line correctly.
Thanks, Richard
iicap
Thanks Terry, sounds good to me. Richard
dgjks6
I took pics of mine before I took it off. Same Serial number as you - came with c-85 stickers, but listed on toro website as c-81. In the pics the rear end is off.
iicap
Thanks to you too dgjks6, no question where all goes now. On a lighter note I smiled and laughed at the electricians wire nut in second pic as mine had the same thing, wire nuts on the tailight feed and grnd wires. Now is that factory connections or home repair :banghead: . Mine had the plastic fender pan, now has metal one.
Thanks again, Richard
