iicap 1 #1 Posted January 6, 2011 Hi, can someone tell me the factory, correct, way to route the fuel line on a 1981 C-81 after it goes thru the support near the trans/axel dipstik tube to where it come out under the dash tower at the frame. I'm in that area now doing lift linkage repair and want to route the line correctly. Thanks, Richard Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #2 Posted January 6, 2011 Try this (same principal/design) : http://www.wheelhorseforum.com/index.php?showtopic=18689 Share this post Link to post Share on other sites
iicap 1 #3 Posted January 6, 2011 Thanks Terry, sounds good to me. Richard Share this post Link to post Share on other sites
dgjks6 8 #4 Posted January 6, 2011 I took pics of mine before I took it off. Same Serial number as you - came with c-85 stickers, but listed on toro website as c-81. In the pics the rear end is off. Share this post Link to post Share on other sites
iicap 1 #5 Posted January 6, 2011 Thanks to you too dgjks6, no question where all goes now. On a lighter note I smiled and laughed at the electricians wire nut in second pic as mine had the same thing, wire nuts on the tailight feed and grnd wires. Now is that factory connections or home repair . Mine had the plastic fender pan, now has metal one. Thanks again, Richard Share this post Link to post Share on other sites
