wolverine_cz 0 #1 Posted January 2, 2011 I had to remove a K241 from my C301 Wheel Horse Tractor. Now replaced and functioning, I have had difficultly getting the throttle linkage and govener set correctly. Either the RPM is too high or too low. Could someone describe the proper method to set the throttle The thottle lever is also worn and doesn't stay in place. Any advice to tighten it up? Thanks.... Share this post Link to post Share on other sites
rmaynard 17,642 #2 Posted January 2, 2011 It's very well described in the Kohler engine manual. Do you have a copy? If not, here is a link: http://www.kohlerengines.com/onlinecatalog/pdf/tp_2379.pdf Share this post Link to post Share on other sites
