420lse 18 #1 Posted January 2, 2011 Tech H70 Won't start Not getting any spark. Points appear to be in good shape. Put in a new Coil. Any ideas? Thanks Moe In CT Share this post Link to post Share on other sites
hoppy 0 #2 Posted January 2, 2011 clean the points with a dollar bill. is the coil new new? ive read of guys replacing two or three coils off the shelf and have them bad. try another coil maybe? condenser? try a differant plug? Share this post Link to post Share on other sites
wheelhorse656 20 #3 Posted January 2, 2011 I have a new points and condenser set for that motor new points and condenser cost $6 a set. make sure the points are gaped at .20 and your plug at .28. just a gusse :ychain: Share this post Link to post Share on other sites
420lse 18 #4 Posted January 2, 2011 The coil is new, spark plug is new too Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #5 Posted January 2, 2011 Have you checked the "kill" wire or switch? Perhaps something is grounding when / where it shouldn't be. Did you change the condenser? Share this post Link to post Share on other sites
420lse 18 #6 Posted January 2, 2011 I Didn't change the condenser. The engine is on a mid 1980's snow blower. Has a 2 safety swiches. Can I bypass the swiches? Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #7 Posted January 2, 2011 Disconnect the ground ("kill") wire at the engine to snowblower connection for "diagnostic & troubleshooting" purposes only. If you get spark with the ground wire disconnected, it's in the harness/switches on the machine. If you suspect a safety switch, test it's function with a meter and replace if bad. If you don't get spark with the wire disconnected, inspect the "kill" wire from the insulated stud at the points to where ever it terminates. These engines are notorious for that wire rubbing against the shield behind the flywheel (or any part of the engine itself) and grounding out the magneto (a.k.a. - a direct short to ground) It could also just be the condenser. :D Share this post Link to post Share on other sites
