3spaniels 0 #1 Posted December 31, 2010 As you may know, a few weeks ago I acquired a D-250 that was listed in the classified section. There are a couple of things I need to address and one of them is the headlamp lens. It is cracked through the diameter of the lens vertically. While I have not tried to remove it at this time, I suspect it will come out in more than one piece when I do. I have been watching the usual places, i.e. Red Square classified, eBAY, Craigslist, etc. but, to no avail. Anyone have any ideas where to find one? :ychain: Share this post Link to post Share on other sites
Kelly 1,033 #2 Posted December 31, 2010 Not sure, but I think those are sealed beam lights mounted in rubber grommets?? if so you should be able to buy a new light at a auto parts store. Share this post Link to post Share on other sites
clintonnut 126 #3 Posted December 31, 2010 There is a screw in the bottom of the bezel. Take it out and the whole bezel and lens comes out. Toro still sells the lens but its around $40. Check out partstree.com. Enter your model which should be 91-20RG01 or 81-20RG01. Share this post Link to post Share on other sites
