Countdown To Christmas!
Operator
D-200
Operator
OK D-Guys I'm putting my pto on my D-200 and I seemed to have misplaced the drive belt. Anyone happen to have a number for a new one?
Randy
wh79d160
Yes, I'll go get it
wh79d160
000_0013.jpg, The :D # is 103084 or, if you want a cool red kelvar one, I may be able to help you out or if you want to get your own, it's a 5/8 x 38" (as you can see) :ychain:
Operator
Thanks a bunch! That Rotary brand, never heard of that? Let alone heard of the Kevlar type. Red would be kind of neat wouldn't it! I can check around town here and see if I can find the Kevlar type.
If you want to PM me a price from you.
Randy
4xfourfun
Did you get your D PTO belt Randy?
I got a heavy duty Napa(Gates/green) for around $15, too bad it wasn't red!
Here's the info Jim M sent me:
"The Wheel Horse part# for the belt is 103084, the Gates number is 6938 and the NAPA number is 5L380W. The trade size of the belt is 5L380"
-Ben
Operator
Yup I found it in town here. Gates brand kevlar, $15.00 to me. I have some other
parts coming in on tuesday so I'll get it then, not red huh?
Thanks for the other numbers, I'll make a note of them.
Randy
Operator
Got my new belt [yup green!] on my D-200. Went to tighten it and it stops short
of tight! Thinking to big may need a shorter one . But then I got to looking at the front bearing hanger under engine, the bearing housing is on the backside of the slide adjuster and hits the crossmember. So I'm thinking I need to pull it apart [after the snow is done] put bearing on front of slide bracket then hope it tightens.
Or just buy a shorter belt?
Randy
Brrly1
OEM. See Ya, Bye Burly :thumbs:
:banghead:
Brrly1
Randy, I am just going to do some guessing here. I would probably be willing to bet that might be the original belt or possibly replaced once. That tractor is the 79 that you have listeted in you signature. I would almost bet its an original belt that has lasted this long so why waste your money on other belts. I guess I believe in OEM. I'll check with Carl and see if might happen to have one in stock. I checked the #103084 and they are like $37 and some change. Talk to you soon John
Operator
Thanks John. I figured this belt would work as it is Kevlar tough. :banghead: .
It wouldn't take much more to be tight but the bearing may be on the wrong side.
Randy
