Countdown To Christmas!
dclarke
rm367 deck decal
dclarke
Would anyone have a good picture of the deck height adjuster decal or know what numbers go next to each height adjustment hole on an 857 mower deck? i think the deck is an rm367. i'd like to see if terry can make them but this is the only pic i have. thanks, Denny.DSC00801.jpg
wh79d160
I put in an order w/Terry last night & I thought I saw that decal on his site. :ychain:
dclarke
Tom, the only one i saw on his site today was a universal one. I'll look again, mabey i missed it. thanks Tom.
dclarke
i dug around and found another deck with this decal. i was able to get the decal size 5/8 x 3 3/4" but i'm not sure of the numbers printed on it. by looking at both pics i'm guessing they are 1 1/2 - 1 3/4 - 2 1/8 - 2 1/2 - 3 - and 3 1/2. any educated guesses or corrections are certainly welcome. thanks TT for correcting me on the name of this decal. i learn something every day on this forum. Denny.DSC00815.jpgDSC00801-1.jpg
Vinylguy
I will try to get this template done and ad to the store soon.
can you get the spacing dimensions for me?
From top to center of first black mark then center to center
Thanks
dclarke
Thanks
Terry, the decal measures 5/16" from end to center of black bar on both ends. the black bars are 1/8" x 1/8" and are 5/8" apart center to center. the whole numbers are 5/32" tall and the fractions are 3/32" tall. anything else you need, let me know. thanks, Denny.
Vinylguy
The font is not exact but is as close as i could get
an should work fine. All dimensions are correct.
Thanks for the help.
Waht year and deck size are these for?
The original looks to be white
but i will make a few of the linnen beige color as requested Denny
Thanks again.
TT
What year and deck size are these for?
Should be 1966 to 1969 32 & 36 inch gear-driven / two-blade / rear discharge decks.
I'll see if I can verify that. :ychain:
Edit:
P/N is 6743 ~ used on the following:
Vinylguy
Thanks TT
Maybe parts tree shows other decals used on those
might as well get those together also.
TT
Uhhhhhh......... :ychain:
There should be two of the #3710 "keep well greased" arrows and two of the #4570 "caution" decals too.
I think that's it - without taking a walk to the shop. :D
Let me see what I have stashed on the 'puter first. :D
OK - found this pic of my RL-366:
Now we need to see what you already have on file. :hide:
linen beige
Is that 2 1/8th marking correct? All the other numbers are in 1/4 inch increments.
TT
OK, Mr Wizard........
You have the "grease arrow" decals and almost the same CAUTION decals in this set:
http://www.redoyourhorse.com/servlet/the-9...D-GREASE/Detail
I'll have the update on the CAUTION decal in a few minutes. :ychain:
Vinylguy
I am not sure Jim, Just going off the provided info.
You may be right.
I cant make it out from the image but 1/4 inch makes sense.
Vinylguy
Thanks again TT :ychain:
I am packing up my laptops and heading across the street for Pizza.
Will check back after supper.
TT
2 1/8 is correct. It has to do with the arc of travel of the gauge wheel assembly.
Here's the CAUTION decal photo:
Text reads:
CAUTION
STAND CLEAR
KEEP FEET AWAY - REVOLVING BLADES
1. OPERATE MOWER ONLY FROM SEAT
2. CLEAR CUTTING PATH OF DEBRIS
3. KEEP CHILDREN AWAY
4. NEVER LET ENGINE RUN UNATTENDED
Dimensions should be the same as this one:
http://www.redoyourhorse.com/servlet/the-1...L-DESIGN/Detail
(I forgot to measure it :ychain: )
Vinylguy
Sweet!! I will work on it tonight and
have listed for the guys soon.
dclarke
Thanks Terry for going above and beyond, again. :ychain:
dclarke
and Thanks TT, for all the info and expertise you so willingly share. :ychain:
linen beige
Yep! That's clearly an "eight" in this pic.
I went out in the cold and looked at mine. Half the decal is missing. Guess which half.
Vinylguy
The Listed Kit
Thanks againt TT :ychain:
bobert94
Its been 5 weeks and still waiting on decals from terry. Never had a problem getting decals from him before. Wont even respond to my emails. :ychain:
Duff
Its been 5 weeks and still waiting on decals from terry. Never had a problem getting decals from him before. Wont even respond to my emails. :D
Sounds like something is snafued in the email department, either his or yours - Terry' s usually fairly quick in replying to folks. Have you tried calling him? (phone number is on his web site).
Duff :ychain:
bobert94
no i didnt try calling him. We had emailed each other several times about the decals i wanted and i ordered them. Well when the order came it was'nt quite right. I emailed him right away,and he said he new what the problem was and would take care of it. Since then he has'nt respoded to my emails. Terry does great work and i have never had a problem before. and i will continue to do buisness with him. just sad only needed these last ones for my restoration. :ychain:
Vinylguy
Robert
Are you the one who needed a shift serial with 1972 on it.
Please pm me or respond to this post. I have two that have fallen under the desk so to speak. Will get you taken care of ASAP
Sorry for the oversight.
