6wheeler 675 #1 Posted December 20, 2010 Well, I did it gentlemen. Broke off an exhaust flange bolt on a Kohler command 20, that i shoehorned into a JD 116 . And of course, that wasn't good enough. I drilled it, inserted my handy easy out. And, easily snapped it off too . I don't know what to do now. I can't drill it or, at least I don't know what to use. The blue flame penetrating solution I would usually use in this situation, won't work (aluminum head and all). Any Ideas? I heard that a masonary bit running slow might get it drilled, But, I have never tried it.. Thanks Pat Share this post Link to post Share on other sites
Operator 7 #2 Posted December 20, 2010 The easy out - out? How about a "backwards" drill bit, great $$ quality? Just a little bit heat? Weld a nut to top? more than likely not huh? Randy Share this post Link to post Share on other sites
6wheeler 675 #3 Posted December 20, 2010 All those thoughts ran thru my melon too Randy. Its broke off just below the surface. Dang it anyway(edited in case of younger viewers). I have to find something harder than the easyout to drill it. I was told a masonary bit is as hard as it gets. But, I don't know. I was also told to heat it up and cool it and heat it again to soften the easyout. But, as soon as I start the aluminum gets hot. Maybe a new head is in my future.... Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #4 Posted December 20, 2010 Three letters for you: E D M - which stands for Electro Discharge Machining. The large machine shop where my father worked (as a tool room attendant) for many years had what they referred to as a "tap disintegrator". Check this out --> http://www.metal-disintegrators.com/ You could try a plasma cutter (or water-jet machine?), but I'd say the best way to get that stud / broken extractor out of the aluminum head would be EDM. Looks like you'll probably have to pull the head anyhow - and buy the appropriate gaskets and new bolts. (thanks a lot, Japanese Kohler ) So now all you have to do is either find someone who has one of those $$$$$$ machines - or find another cylinder head. Share this post Link to post Share on other sites
puddlejumper 67 #5 Posted December 21, 2010 I am just repeating something I read on another thread. But somebody said they removed a (hard out) with a dremel tool and the little carbide cutters available for them. Never tried it but he commented that it took hours but was successfull. :ychain: Share this post Link to post Share on other sites
Operator 7 #6 Posted December 21, 2010 Three letters for you: E D M - which stands for Electro Discharge Machining. The large machine shop where my father worked (as a tool room attendant) for many years had what they referred to as a "tap disintegrator". Check this out --> http://www.metal-disintegrators.com/ You could try a plasma cutter (or water-jet machine?), but I'd say the best way to get that stud / broken extractor out of the aluminum head would be EDM. Looks like you'll probably have to pull the head anyhow - and buy the appropriate gaskets and new bolts. (thanks a lot, Japanese Kohler ) So now all you have to do is either find someone who has one of those $$$$$$ machines - or find another cylinder head. It is amazing the things that can be learned about on Red Square!! That is one amazing machine! Pat I don't have one of those here. New head Randy Thanks TT Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #7 Posted December 21, 2010 A tungsten-carbide or diamond tipped drill bit would also get it out of there, but the stud is only 8MM (I believe) and trying to hold a hand drill solid and steady enough would be a challenge in itself. Share this post Link to post Share on other sites
JimD 3,347 #8 Posted December 21, 2010 Thanks for the idea TT. We have a wire EDM at work. I'll have to remember that in the future for all my broken stuff. :ychain: Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #9 Posted December 21, 2010 The wire EDM process is a little different, Jim. Burning out broken bolts, etc. would require a sacrificial electrode that doesn't pass through the workpiece. 25 years ago when I was machine shop student, the electrodes we used were made of machinable carbon. I have no idea what the composition of them would be in this modern age. Share this post Link to post Share on other sites
6wheeler 675 #10 Posted December 21, 2010 Thanks for your help Terry, I agree with what you said, I took the head off. I did enough damage myself trying different things. I think if I am going to drill it ,a drill press is going to be a must. We have a welding guy fairly close to me and, I think he does some machining too. So, I am going to run it up there and see if he can get it out. Thanks again. Pat Share this post Link to post Share on other sites
Kelly 1,038 #11 Posted December 21, 2010 I may have a head if you need one. Share this post Link to post Share on other sites
sorekiwi 761 #12 Posted December 22, 2010 One of the other guys at work broke an easy-out off in a bolt a couple of weeks ago. I thought it was going to be a major PITA and was thinking EDM, but one of our machinists just bored the thing out with a plain carbide endmilll (in the Bridgeport). Cut through the easy out as easily as it cut through the broken bolt. Share this post Link to post Share on other sites
sgtsampay 117 #13 Posted December 22, 2010 Wow. I think that EDM thing is cool. Sure wish I knew about that a few month ago when i had 3 stuck bolts in an engine i was rebuilding,. i have to drill them out with the drill press... Thats was PITA! Share this post Link to post Share on other sites
buckrancher 2,696 #14 Posted December 22, 2010 we have six edm machines at the company I work for and I'll use a bridgeport mill and a good center cutting carbide endmill. to remove broken bolts,studs etc. our carbide endmills will cut thru easy-outs like a warm knife thru butter We normaly use the edms on small size threads like 1/4-20 and smaller as 99% of what we're burning out is a broken tap Brian ( I can mill thru a cutting tap also with our endmills at 2500-4000rpm) Share this post Link to post Share on other sites
Coadster32 793 #15 Posted December 23, 2010 I'll use a bridgeport mill and a good center cutting carbide endmill. to remove broken bolts,studs etc. I second that with my experience as well. Share this post Link to post Share on other sites
