yorkiesB-80 0 #1 Posted December 18, 2010 First problem with my B-80 went to start it today it was dead Battery is fully charged did some testing it traced it some where around switch , I replace it didnt work. attached to the wireing harness is as extras plug not used that had a broken black wire that was wrapped up so i touched the wire to the coil and the engine started and stays running once i remove it (if you leave it connects it will keep engaging the starter .Im thinking the wire from the coil to the key is broken but havent run a jummper yet till tommorow . Has any one had this problem? Share this post Link to post Share on other sites
rmaynard 17,105 #2 Posted December 18, 2010 Do you have a good wiring diagram? If not let me know. That is the first place to start. Bob Share this post Link to post Share on other sites
