gattonde 1 #1 Posted December 15, 2010 I had my driveway asphalted this year and wondering if Tire Chains will tear it up. Has anyone plowed snow from their asphalted driveway with Chains attached. Thanks for any Help. Dan Share this post Link to post Share on other sites
Trouty56 565 #2 Posted December 15, 2010 I get some white scratches but hey, it's a driveway!! I'm not that particular. It doesn't tear hunks out of it or anything. Just white scratches. Share this post Link to post Share on other sites
danjmah 71 #3 Posted December 15, 2010 I get some white scratches but hey, it's a driveway!! I'm not that particular. It doesn't tear hunks out of it or anything. Just white scratches. What Bob T says, I get the same. Share this post Link to post Share on other sites
rmaynard 14,908 #4 Posted December 15, 2010 Ditto the above. No serious damage, only cosmetic. Share this post Link to post Share on other sites
wheelhorse656 20 #5 Posted December 15, 2010 i use plasitic bar and nyolon chains they do neither and work just as good. Share this post Link to post Share on other sites
HankB 16 #6 Posted December 15, 2010 I get some white scratches but hey, it's a driveway!! I'm not that particular. It doesn't tear hunks out of it or anything. Just white scratches. Likewise. But I'm not using V-bar chains. Regular chains just scratch off the topcoat. I guess I'm more particular. Or maybe I was just looking for an excuse for a set of ags. I've switch to ags for snow plow duty, fluid filled them and haven't looked back. Share this post Link to post Share on other sites
GlenPettit 1,714 #7 Posted December 15, 2010 If you are just driving on it carefully, pushing light snow, you will not noticeably tear or scratch up the drive, BUT . . . if you spin the chains at all, there will be noticeable scratches, and they can be very noticeable. Weight will improve traction and reduce the chance of spinning, but nothing beats driving and plowing carefully. If the snow is wet and heavy, it will take more effort, light fluffy snow is very easy to plow. It all depends you you. When you seal the drive, the scratches are easily covered. Good Luck, GHen Share this post Link to post Share on other sites
bk-scouter 93 #8 Posted December 15, 2010 I'm trying out a set of rubber chains that I bought off of "Mainedad" (Micah) earlier this fall. I was not liking the the white scratches my chains were leaving on my concrete drive, so these seemed to be a logical alternative. Last Sunday I put them to the test twice and they did a very nice job, even better than my 4- link chains. Now I don't have to park the rear tires onto wood blocks anymore to prevent the rust stains getting on garage floor. -BK Share this post Link to post Share on other sites
Horse Fanatic 49 #9 Posted December 15, 2010 As others have said, they do scratch the driveway. I didn't care on my old driveway and used chains and they worked well. I got the driveway repaved a couple years ago and didn't want to mark it up, so I got some ags and filled them. Those along with the weights work as well as the non-filled turf tires I was using with chains and they don't scratch the asphault. Share this post Link to post Share on other sites
Shuboxlover 474 #10 Posted December 15, 2010 I get some white scratches DITTO!!!! now what you DON'T want to do is use your tractor with tire chains on two week old concrete :D Share this post Link to post Share on other sites
Butch 194 #11 Posted December 15, 2010 I get some white scratches DITTO!!!! now what you DON'T want to do is use your tractor with tire chains on two week old concrete You didn't. Not on 2 week old concrete. Did you? Heck you can just about still trowel 2 week old concrete! B) Share this post Link to post Share on other sites
Redbirdman 7 #12 Posted December 16, 2010 Yeah....... don't stand there spinning and you wont have a problem! The big problem is when you CHARGE someone for plowing and you scuff,,,,, specially on PAVERS! Or on SLATE! I actually did more damage backing up a hill than pushing.... But those days are over............now I only worry about driving into a pool! :ychain: Share this post Link to post Share on other sites
Shuboxlover 474 #13 Posted December 16, 2010 You didn't. Not on 2 week old concrete. Did you? Heck you can just about still trowel 2 week old concrete! Yep....I sure did temporary lack of judgment.... or too much power I don't look at them as chain marks.... I look at them as Wheel Horse shoe marks :D Share this post Link to post Share on other sites
Save Old Iron 1,563 #14 Posted December 16, 2010 and of course if anyone has a driveway beginning to "alligator" or crack slightly, chains catching in a crack will dislodge larger chunks of the already compromised asphalt and degrade the surface even more. Share this post Link to post Share on other sites
PPGman 5 #15 Posted December 16, 2010 I have a couple sets of chains and they do mark the asphalt, as well as the concrete if you spin. My V-chains offer the best traction, and i have found that they are actually better as they spin less. Wheel weights also greatly help with the wheel spin issue. The key is to operate without spinning the tires. Heaver snow, you might have to take less of a bite. Light snow you can hook her in high gear and get'r' done mode! Make no mistake about it though....if you sit there and dig and spin, your asphalt will be a mess I know alot of guys on here use loaded up ag type tires/ no chains, with good results. This idea never apealed to me as i know what a farm tractor with ags and no chains does in the snow; but i'm changing my thinking on this since alot of guys here run that setup and say how well it works for them. This might be the next set up i try when my boys start doing some of the snow plowing duties around the house. But for the most part, my chains have served me well with minimal damage. Share this post Link to post Share on other sites
