JMW 3 #1 Posted December 15, 2010 Ok here is my question. I have an older starter/generator 12hp kohler that I am putting on a c-160 but the mounting surface is wider than the frame. Is this normal or do I need a different mount or oil pan ? Can I just make an angle iron bracket for it? Thanks for any help or ideas. Jim. Share this post Link to post Share on other sites
Kelly 1,038 #2 Posted December 15, 2010 The bottom of the oil pan should have threaded holes for bolts on that side, tip the engine up and take a peek. Share this post Link to post Share on other sites
JMW 3 #3 Posted December 15, 2010 Thanks Kelly.It did come out of a wh but I never thought to flip it over and look for threaded holes. Share this post Link to post Share on other sites
Don1977 606 #4 Posted December 15, 2010 I checked the oil pan on my old 12 HP and it has 4 tapped holes in the pan 2 on each side. I always though that they were only on one side. Share this post Link to post Share on other sites
Kelly 1,038 #5 Posted December 15, 2010 Oil pan will fit on both ways, just depends on were you want the oil drain, so it needs holes on both sides. Share this post Link to post Share on other sites
