ryan2121 1 #1 Posted December 13, 2010 After restoring my 76 c120 I installed the rod cap wrong and it locked up. So I thought I found a good deal on ebay for a rod and crank so I grabbed them and got everything installed with no problems. Until I went to put the pto pulley on, It seems my stock crank had a 1 1/8 shaft and the new crank I got is a 1" shaft. Is there a different pulley I can run to compensate for this, or do I have to buy another crank for the 1 1/8" shaft? Share this post Link to post Share on other sites
Kelly 1,037 #2 Posted December 13, 2010 Yes but if you have a hydro they are not a common pulley if you have a 8 speed a drive pulley from a 8hp tractor or a briggs powered tractor with a 8 speed will work, they used the 1" crank, you will also need the PTO sleeve for the 1" crank also. Share this post Link to post Share on other sites
ryan2121 1 #3 Posted December 13, 2010 Mine is the 8 speed so all I should need is the pulley and the pto sleeve? The rest of the pto will interchange? Share this post Link to post Share on other sites
Kelly 1,037 #4 Posted December 14, 2010 Yes a pulley and sleeve you will be all set. Share this post Link to post Share on other sites
dgjks6 8 #5 Posted December 14, 2010 I am still on the search for the 1 inch PTO pulley. I gave mine to a member here thinking I was not going to reuse it. The k181's had the 1 inch pulley, all the rest have the 1 1/8. The 1 inch pulley's show up from time to time, but they are not as common as the 1 1/8. There is a pulley on ebay now for $80. Share this post Link to post Share on other sites
ryan2121 1 #6 Posted December 14, 2010 Is that a common price for them, I have a 1 1/8 crank before I would pay 80 for the pulley I would just put my other crank in there. Share this post Link to post Share on other sites
Kelly 1,037 #7 Posted December 14, 2010 I was looking for one for another member here, but I don't have one, I was going to ask $20 plus shipping. Share this post Link to post Share on other sites
Don1977 605 #8 Posted December 14, 2010 I would check with a machine shop to have the pulley bored out, sleeved and keyed. The PTO sleeve can also have another sleeve inside to bring it down to 1". I have that setup on my C-120/180 with the Briggs Vanguard 18. That may be a way to get your tractor back operational. I did that to mine in 1990 with a 16 Briggs Vanguard that gave up last spring. Share this post Link to post Share on other sites
dgjks6 8 #9 Posted December 14, 2010 That is a great idea. I just left the machine shop and I will see how much he will charge to do it. Share this post Link to post Share on other sites
