WHEELMAN
hyd lift cylinder
WHEELMAN
i have a welded hyd lift cylinder on my 1276.
is it possible these cylinders could leak internaly?
can anyone tell me if a replacement cylinder is
available. it is a wheel horse pn 6618 thanks.
Indy w h
Yes they can "leak" inside. There are O-rings on the piston that over-time wear out. You can take it to a machine shop and they can put it In a lathe and "cut"the welds
Then you replace the O-rings and re-weld it
Indy
