Pirate
How much will a manual sleeve hitch lift?
Pirate
I have a 414-8 with no hydraulics.
I have a chance to buy a 8hp rototiller, that has a sleeve hitch.
Just wondering if the manual lift on my WH will lift the tiller, with the 8hp motor on it.
I will have to fab the rock shaft, and could play with the arm lengths on the shaft, to get more leverage. But less lift.
Any ideas?
Here's a pic of the tiller:
WheelHorse_of_course
The picture you show has a 3pt hitch.
The Brinly box graders are probably as heavy as that tiller. As long as you don't mind one Popeye arm and one normal arm I would not worry about the weight.
Since you have to make it anyway, make it for a slot hitch if that is what your horse has already.
I think what I would do is make a hitch with a hinge in the middle, so that it rocks the tiller back onto its wheels for transport. That way you are lifting nearly no weight.
Just an idea I dreamt up thinking about making a tow behind tiller.
Be sure to show us pictures of the final project.
:D :ychain:
Pirate
WH of course. I like the idea of a hinge, and lifting it onto the rear wheels, for transport.
I've got a tine, dethatcher, that I sometimes, set the height with the rear wheels, so the tines just pick up pine needles. A hinge with work with that also.
Good thinking.
Post some pics if you do it. The hinge idea is just a thought, so I'll be interested if it works in theory!
I have often though a tiller like this is far more likely to fit my budget that a Wheel Horse tiller.
Happy Holidays of you choice. :D :ychain:
Here's Wheel Horse's idea with the hinged tongue. I have one of these and it isn't very hard to lift with the slot hitch.
http://www.wheelhorseforum.com/index.php?showtopic=1220
Good to know it should work.
And no surprise I did not invent it - I had no idea where the idea came from, now I know - all I know is it was just in my head!
Hard to find self-powered tillers though.
:D :ychain:
linen beige
:ychain:
Rollerman
:D:ychain:
Actually that is a sleeve hitch hanging off the front of the tiller.
Just set up for a differant make.
The pin looks to be right at the front of the tiller.
So you won't have a whole lot of weight hanging out.
If it seems to hard to yank up you can always try a helper spring or two.
hm12460
Pirate, it depends on how tuff ya are!
