Docwheelhorse
C125 with Eaton Drain and Fill Specs
Docwheelhorse
Hello All---
I picked up a C125 yesterday with the Eaton in it---Sparky taught me to look for the filter coming straight out the back on the top left. :thumbs: Anyways---what does this thing use for transmission fluid (I assume 10/40), how much oil and what would the part number be for the filter at NAPA? It needs a change and I'm going to tackle it this weekend.
Thanks All
Tony
WH854
Toro P/N 79-5270 replaces 108335 Oil 10W40 Mine holds 5 QTS. When you fill it don't put all 5 in then check,check it as you go, all the oil will not come out when you drain it. :thumbs:
Chas
Docwheelhorse
Thanks!!
Tony
