tinkerbell 0 #1 Posted November 21, 2010 :thumbs: I currently own a late 60's model tractor(not for shure). I was told that this model was produced for one year. I know it has a 10hp engine that runs. There is one problem with it something to do with the starter and charging system. A bearing of some sorts has went bad. I used it to mow our yard untill this past summer. I can not fix it and know it is worth more than hauling to a scrap yard. I do not know wht it is worth. Help me find this tractor a new home so mabe I can have a down payment. Share this post Link to post Share on other sites
KB9LOR 4 #2 Posted November 21, 2010 I currently own a late 60's model tractor(not for shure). I was told that this model was produced for one year. I know it has a 10hp engine that runs. There is one problem with it something to do with the starter and charging system. A bearing of some sorts has went bad. I used it to mow our yard untill this past summer. I can not fix it and know it is worth more than hauling to a scrap yard. I do not know wht it is worth. Help me find this tractor a new home so mabe I can have a down payment. If you look in front of the shifter mounted to the dash tower (below the dash plate, where the key is inserted) you should see a model number and below that a serial number, check and post here what you find, then we can tell you what you have, or post a picture of it. Share this post Link to post Share on other sites
jusjeepn 59 #3 Posted November 21, 2010 Where are you located? It will cheaper to repair this than to replace it with a box store throw away! Get the model number and you'll get plenty of help here locating parts and even repairing it! Share this post Link to post Share on other sites
Sparky-(Admin) 25,557 #4 Posted November 21, 2010 Sounds like you have a 1045 . That would mean you have a 10hp Kohler with a starter/gen setup, manual tranny, square hood and rounded rear fenders. Right? If your not inclined to repair the starter/gen how about just replacing the whole thing. That would be a simple bolt off/bolt on repair. Mike....... Share this post Link to post Share on other sites
wheel horse 1045 2 #5 Posted November 21, 2010 it could also be a 1067 0r a 1076 or a 1077 or a 1075 or a 1055 just a few, we need pictures and welcome to redsquare Share this post Link to post Share on other sites
