harleyjj 2 #1 Posted November 19, 2010 Is it necessary to put snow chains on agricultural tires for plowing snow? I have a C-111 with a 42" blade that I will be plowing with and was curious if these tires plus my 240lbs will be ok or if I need chains? Share this post Link to post Share on other sites
Kelly 1,038 #2 Posted November 19, 2010 I prefer turf tires with chains, ags don't do as well, I've used both, and ags with chains need to be at least 2 link so they don't drop between the lugs. Share this post Link to post Share on other sites
sorekiwi 761 #3 Posted November 19, 2010 I prefer turf tires with chains, ags don't do as well, I've used both, and ags with chains need to be at least 2 link so they don't drop between the lugs. And I say what he (Kelly) said!! I use weights as well, but I'm only 160 lbs. Share this post Link to post Share on other sites
Kelly 1,038 #4 Posted November 20, 2010 Yes I use weights also, at least 50lbs, one tractor has 75lbs I only weigh 180 I need all the help I can get. Share this post Link to post Share on other sites
wheel857 0 #5 Posted November 20, 2010 i think that ag tires are over rated for yard work. i dont like how they tear everthing up. pluss on snow packed hard or ice then the tire is cold and hard there for they dont mash down and u will find out you will spin alot do to ridding on top of the lug.. chain and yards for me pls :thumbs: Share this post Link to post Share on other sites
Sarge 3,471 #6 Posted November 20, 2010 Ags work great but only with extreme weight - got 2 workers set up with cast weights and 7 gal of fluid in each - 140lbs for each tire. It doesn't spin and in fact one has nearly flipped over backwards once. Turfs and chains, for the most part, are much better and no they don't tear up the grass. Sarge Share this post Link to post Share on other sites
slufoot733 70 #7 Posted November 20, 2010 Ag tires work in sofe dirt but not so well when plowing snow. Snow plowing is usually done on pavement or hard packed gravel and the lugs just don't dig in. Chains on terf tires with weight is the only way to go. K Share this post Link to post Share on other sites
AMC RULES 37,259 #8 Posted November 20, 2010 Think about and watch what you're doing. Those chains can/will do a number to the driveway/blacktop if you're not careful. You might not notice it until spring. :thumbs: Share this post Link to post Share on other sites
hoosier 1 #9 Posted November 20, 2010 Is it necessary to put snow chains on agricultural tires for plowing snow? I have a C-111 with a 42" blade that I will be plowing with and was curious if these tires plus my 240lbs will be ok or if I need chains? I use one tractor with turfs,weights, and chains, and another with Ag's and weights. I prefer the one with Ag's for snow mostly. It is weighted a little heavier though, and works best for my conditions. A lot of ice is another matter. In those cases the one with chains comes out of the shed. You might just try it 'as is' and see. Share this post Link to post Share on other sites
hm12460 53 #10 Posted November 21, 2010 Yup! What Kelly said, you gotta trust me on this, us Michi-ganders know how to plow snow. Share this post Link to post Share on other sites
KC9KAS 4,746 #11 Posted November 21, 2010 Last winter was the 1st time I used a garden tractor for snow removal. I have used large tractors and dumptruck/plow equipment. I used a 1964 654 with turf tires and chains. I weight 240# and I really needed additional weight when pushing snow, as I was "spinning" my wheels a lot of times. I did find some weights this summer, but they are FMC and only have 2 mounting bolt holes, and they are not a direct fit to the WH wheels. I did buy a device to pump fluid into the tires, but have not completed that process either...maybe it won't snow this year! Share this post Link to post Share on other sites
wheelhorse656 20 #12 Posted November 21, 2010 i suggest useing no chains if you have ags and take alot of air out of the tires for taction. Share this post Link to post Share on other sites
HankB 28 #13 Posted November 21, 2010 I used ags late last winter to avoid scratching up my asphalt drive. I thought liquid filled ags did as well as 4 link chains on turf tires. That's on a 314-H that weighs in at 700 lb (w/out the blade.) I add about 200 lb right over the rear wheels. I've heard that chains slip between the lugs on ags so that's probably not an optimum combination. -hank Share this post Link to post Share on other sites
bitten 134 #14 Posted November 21, 2010 I have only used ags with chains and they seem to work just fine. I do use the two link and this is on a D200 that is heavy out of the box. I am going to install front wheel weights on it this year to help with steering. Share this post Link to post Share on other sites
