Joycie 0 #1 Posted November 9, 2010 i have a 1065 1055. just because i'm a girl dont mean i dont know about my tractor. i do need help getting the hardware to attach the blade to my mower. i need a trusted source preferrebly in the lancaster pa region. if you have any ideas or advice, ill take it!!! thanks!!! Share this post Link to post Share on other sites
oldredrider 2,547 #2 Posted November 9, 2010 Tractors aren't just for guys! Here's what you need to know about the install: http://www.wheelhorseforum.com/index.php?showtopic=291 Share this post Link to post Share on other sites
TT-(Moderator) 1,128 #3 Posted November 9, 2010 That post doesn't really pertain to a 1055 - which would use the bracket made out of angle iron mounted vertically to the front of the axle housings and a solid lift link hooked directly between the blade frame and the lift arm. Knowing exactly what blade you're attempting to use would be helpful too, since the newer blade frame would need the newer axle bracket. This is the correct style of blade used on the 1055: I can get a picture of the rear axle bracket later if you need it. "Joycie" - it might take a little while, but we'll get you hooked up. (pun intended) :thumbs: Share this post Link to post Share on other sites
