persof 14 #1 Posted November 5, 2010 I replaced the starter on my 312-8 this evening and when I tested my work the starter drive gear "plunger" hit up against the engine shroud??? Otherwise it seems to fit fine. Any ideas? Thanks Francis Share this post Link to post Share on other sites
WH nut 553 #2 Posted November 5, 2010 Are you sure you have the right starter, it looks used Share this post Link to post Share on other sites
Duff 206 #3 Posted November 5, 2010 Francis, did you take the engine shround off while you were working on the engine? I can't tell from the picture, but if the shroud is slightly out of alignment that may be causing the problem. Duff :thumbs: Share this post Link to post Share on other sites
persof 14 #4 Posted November 5, 2010 The starter is new from Jacks Small engine repair. I gave them my Kohler engine # and what the toro part #s were and Jack's parts guy confirmed the number. It is case the same physical size as the original. The shroud is bolted in a number of places around the engine preventing misalignment. Francis Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #5 Posted November 5, 2010 Did you compare the drive style / tooth count / shaft length between the two starters? Share this post Link to post Share on other sites
persof 14 #6 Posted November 5, 2010 All things appear to be the same except for a black plastic "cover" on the starter gear shaft which is almost 3/8" longer than the bare shaft of the stock one. Can I remove it? I tried using moderate finger force and it didn't budge. Thanks Francis Attached Image Share this post Link to post Share on other sites
keg 0 #7 Posted November 5, 2010 i would think the plastic cover should come off? it looks that way but dnt quote me on that lol :thumbs: Share this post Link to post Share on other sites
persof 14 #8 Posted November 5, 2010 I called the manufacturer (Arrow Head) and he said it can be removed. I'll try it tonight. Thanks Francis Share this post Link to post Share on other sites
persof 14 #9 Posted November 9, 2010 That "dust" cover was hard to remove but Idid and all is well Francis Share this post Link to post Share on other sites
