KB9LOR 4 #1 Posted November 2, 2010 I had to replace the 2 pins on the flywheel on the hh100, what is the clearance that you set the coil to on the highest pin? ( When I got the raider 10 it had the highest pin sheared of and would not fire, So I replaced them and do not know the clearance). Share this post Link to post Share on other sites
puddlejumper 67 #2 Posted November 2, 2010 Thjs is somewhat of a funny answer but its the best I can do. On a briggs set the coil against a dollar bills and tighten, remove bills and your on your way. Share this post Link to post Share on other sites
ducky 1 #3 Posted November 2, 2010 i use a match book to set the coil clearance. but not to sure of the correct measurement on the hh100 but ill be doing some checking i have a hh100 that needs work. Share this post Link to post Share on other sites
Save Old Iron 1,563 #4 Posted November 2, 2010 0.010 inch if I remember the last manual I saw. Share this post Link to post Share on other sites
KB9LOR 4 #5 Posted November 2, 2010 Thanks everyone, I will try the .010. Share this post Link to post Share on other sites
Save Old Iron 1,563 #6 Posted November 2, 2010 officially, from the manual 0.006 to 0.010 inches air gap from long pin to ignition module :thumbs: Share this post Link to post Share on other sites
KB9LOR 4 #7 Posted November 2, 2010 Thanks SOI, going to set it halfsies, at .008. Share this post Link to post Share on other sites
