WH854 45 #1 Posted October 29, 2010 Is the bottem and top pully the same size P/N 106073 on the center pully? Anyone have a picture of one Chas :) Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #2 Posted October 29, 2010 Sorry - no picture..... but both grooves are the same diameter - which is the same as the two outer pulleys. Share this post Link to post Share on other sites
WH854 45 #3 Posted October 29, 2010 Thanks for the reply TT Question?? could you use that center pully on a 42" deck and change the blade pullys on the 42" deck to ones used on a 48" deck Chas Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #4 Posted October 29, 2010 You could, but because the blades are shorter on the 42, the tip speed would be lower. Does that really matter? Would you notice a difference in the quality of cut? My answer to both questions would be "I doubt it", but the possibility does exist. You'd also need to "experiment" with the belt length since no OEM deck used that configuration. Share this post Link to post Share on other sites
WH854 45 #5 Posted October 29, 2010 :) Terry for the information I will see what I can dream up Chas :wh: Share this post Link to post Share on other sites
