WH854
Center Pully For 48" Deck
WH854
Is the bottem and top pully the same size P/N 106073 on the center pully? Anyone have a picture of one :thumbs:
Chas :)
TT
Sorry - no picture..... but both grooves are the same diameter - which is the same as the two outer pulleys.
WH854
Thanks for the reply TT :) Question?? could you use that center pully on a 42" deck and change the blade pullys on the 42" deck to ones used on a 48" deck :thumbs:
Chas
TT
You could, but because the blades are shorter on the 42, the tip speed would be lower.
Does that really matter? Would you notice a difference in the quality of cut?
My answer to both questions would be "I doubt it", but the possibility does exist. :thumbs:
You'd also need to "experiment" with the belt length since no OEM deck used that configuration.
WH854
:) Terry for the information :thumbs: I will see what I can dream up :)
Chas :wh:
