Olratlr 25 #1 Posted October 25, 2010 Guys I need your expertise. I ran across a tiller that I think will work with my 520H there are no Serial no. on it but the only way it will go up under the axle's is to remove the Clevis Hitch is this normal? The belt seems to be right and the front attachamatic pulleys work. Thanks. Norm :thumbs: Share this post Link to post Share on other sites
HankB 16 #2 Posted October 25, 2010 ... but the only way it will go up under the axle's is to remove the Clevis Hitch is this normal? Yes. I need to remove the drawbar hitch before I mount the tiller on my 314-H (which at that point is pretty similar to the 520-H) If you post pictures of your tiller, someone here might be able to ID it. But regardless, you can probably go to the Toro site, look up attachments for your tractor and download a manual for the tiller. Even if it is not exact, it will probably be helpful. (Between these two pages you might find something: https://lookup3.toro.com/partdex/index.cfm?...es&xCaller=Toro https://www.shoptoro.com/Comergent/en/US/ad...tProductDetails ) -hank Share this post Link to post Share on other sites
Olratlr 25 #3 Posted October 26, 2010 Thanks a lot Hank! I am pretty sure it will work after moving the Hitch. Norm :thumbs: Share this post Link to post Share on other sites
