DMK855 15 #1 Posted October 19, 2010 I need some pictures of how the throttle cable hooks to the gov. and also pics of any and all gov. springs!! Thanks, Dwayne Share this post Link to post Share on other sites
DMK855 15 #2 Posted October 20, 2010 Bump..... Anyone?? Share this post Link to post Share on other sites
wallfish 18,591 #3 Posted October 20, 2010 Took me a while to find my camera. Let me know if you need anything else. Share this post Link to post Share on other sites
DMK855 15 #4 Posted October 20, 2010 Thanks John!! Is that a spring along with the linkage going to the carb.?? Share this post Link to post Share on other sites
wallfish 18,591 #5 Posted October 20, 2010 The spring comes from the bottom throttle lever up to the governor arm. A wire link connects the governor arm to the carb. Share this post Link to post Share on other sites
VinsRJ 723 #6 Posted October 21, 2010 Dwayne, just responded to your PM.... my RJ's throttle is hooked up a little differently. As far as I know and from the way it looks, I would say its never been messed with. Share this post Link to post Share on other sites
wallfish 18,591 #7 Posted October 21, 2010 Could you post some pics Vin? This was how I received the motor from Charlie with no other clear way to hook it up. Share this post Link to post Share on other sites
DMK855 15 #8 Posted October 21, 2010 Ditto with John!! Better to have more pics!! I was trying to get it hooked up, but my lever was flipped aroud different than what John had posted!?!?!? Share this post Link to post Share on other sites
VinsRJ 723 #9 Posted October 22, 2010 Here she is....... I've got two RJ's, one is a 58 (original 1200) and one is a 59 (original B1290), which both had this throttle linkage set up in the pic below. Specifically its a pic of my my 59 which was purchased from the original owner. IMO its was never messed with until I dismantled the tractor for a complete head to toe cleaning. As you will notice the lower "L" linkage is flipped over compared to both of yours. Next there is a cable clamp holding the cable to the lower bolt of the blower cover. Again IMO this set up makes sense since the throttle cable on a RJ comes in from the left when seated on the tractor. Attached Image Share this post Link to post Share on other sites
wallfish 18,591 #10 Posted October 22, 2010 Thanks Vince, that does make sense. Share this post Link to post Share on other sites
DMK855 15 #11 Posted October 22, 2010 Thanks Vince, that was the direction that mine was flipped. Also, explains why the cable clamp was on the lower bolt like yours!! Share this post Link to post Share on other sites
