Len Haduck 0 #1 Posted October 14, 2010 Hello all, Mowing last evening and deck was making a lot of noise. When I removed it, I noticed the center double pulley bolt attaching it to the spindle had snapped off flush with the top of the spindle bearing. Any suggestion? thanks LEn Share this post Link to post Share on other sites
HankB 28 #2 Posted October 16, 2010 The model or a description of the deck or perhaps pictures would be helpful. I think Wheel Horse used several styles of spindle through the years and repair details could differ. Offhand, I'd ask if you can drill it out. I'd start soaking it in PB Blaster (or your favorite penetrant) because it's likely to be rusted in there. For that matter, start soaking all of the bolts you might need to remove to get the spindle out. Good luck! -hank Share this post Link to post Share on other sites
WH854 45 #3 Posted October 21, 2010 If it snapped of at top of spindle bearing, including the center pully, I would think it would come out the blade side with a little help. Chas Share this post Link to post Share on other sites
Don1977 606 #4 Posted October 21, 2010 He's talking about a Double D spindle. They had a bolt and washer on top to hold the pulley tight. You will have to drill it out. It's best to use a left handed drill bit that may spin it out. You can get left hand drill bits at industrial supply or auto parts. The other fix is to find another spindle shaft. Share this post Link to post Share on other sites
