mattd860 163 #1 Posted October 9, 2010 I need pictures of the linkage and hookups for the cables on a Suburban 550. I will need accurate measurements of the links so I can make them. If someone can also take pictures of the throttle and choke cable routing that would be great too. Thanks Share this post Link to post Share on other sites
mattd860 163 #2 Posted October 14, 2010 Ok a couple members have sent me pictures of the area in question. However each member had a slightly different way to route the linkages. I now know of two ways to route the linkages but still not sure of the 100% correct (factory) way. Member #1: Member #2: So which is the correct way?? :) Share this post Link to post Share on other sites
MikesRJ 563 #3 Posted October 14, 2010 Here's the Tecumseh manual which explains: http://www.mywheelhorse.com/graphics/file/...vice-Manual.pdf Share this post Link to post Share on other sites
mattd860 163 #4 Posted October 14, 2010 Thanks Mike!! I didn't really see anything resembling the governor links. Page 14 of the PDF (16 of the manual) show a typical governor linkage layout but it doesn't look like anything I've seen before. Did I miss something?? Share this post Link to post Share on other sites
MikesRJ 563 #5 Posted October 14, 2010 Nope, you didn't miss anything. I thought that, and teh description, might lead you to the answer. Share this post Link to post Share on other sites
mattd860 163 #6 Posted October 14, 2010 It helps a little. But on the H55B, I don't believe the spring goes between the governor and control lever. The spring should go between the control lever and the throttle control arm (the arm that connects directly to the throttle cable). I think in the end, the routing doesn't matter as long as the governor can effectively control the throttle plate in the carb and also as long as the correct spring is used. I think if the linkages are setup like both examples above, the system should work as intended. Share this post Link to post Share on other sites
