Countdown To Christmas!
ff1110
k181 carb question
ff1110
I got my 1973 8hp 4spd missing the carb and air cleaner. I have been unable to find used ones, will a carb from a 10 hp work? I can't afford to buy new right now.
Don1977
I'm not sure but I don't think a 10 HP carb will work. I think you need a carb form an 8 HP or smaller engine. Some one that knows for sure should post an answer soon.
ol550
A carb from a 4 hp will fit but I don't think you will get enough air for maximun HP. the 7 and 8 hp ones will work out much better. Same as it is hard to dial in a larger HP carb on a 4hp. The 10 and up have a wider bolt patern. Mike
Retired Wrencher
:) :USA::wh: Hi Rick u can try Wheel horse Jeff at TCOF805365@COMCAST.NET he only buys and sells W/Horse tractors and parts he ships all over the country. he probably has on the shelf I do business with all the time. I hope this helps. Gary B....
MikesRJ
The correct engine for both models of the 1973 8hp 4-speed (1-0276 and 1-0277) was the Tecumseh V80.
You have a Kohler installed. Which Kohler engine is it exactly? I assume it is the K181 which means any carburetor from another k91 to K181 would work. Look for one with a number "30" or "32" (meaning 30 or 32mm opening) in a circle on the top inside of the air intake throat of the carburetor.
The original Kohler part number is B-231739, Kohler Carburetor - Part No. 41 853 08-S
Part No. 41 853 08-S AKA 4185308S Supersedes Part No. B-231739 & 41 853 02
VinsRJ
Ya, whatever the heck he said...... :)
CasualObserver
Mike... you're leaving something out.... he'd look awfully funny trying to put a vertical shaft teccy in there! :)
There are also 1973 8hp 4-speed models that have horizontal shaft engines.
MikesRJ
Jason,
Ah yes, of course you are right. I see now that the 1-0120 was equipped with a K181. I missed that the first time around. Thanks for catching it.
FF1110,
Here's the manuals for your model:
Owners Manual: http://www.mywheelhorse.com/graphics/file/...-8-Speed_OM.pdf
IPL: http://www.mywheelhorse.com/graphics/file/...8-Speed_IPL.pdf
ff1110
Yep, my model # is 1-0120. Thanks everyone for all the help! :)
nitnoc420
i also am looking for a Kohler 8 hp carburetor B231739 ...........K181S/30700d on a C-81 serial #9035716
i live in south western PA
sidman pa15955
thanks
tim
