yokomist 0 #1 Posted October 1, 2010 Hello, I have a kohler k241 on a 1056 that is giving me trouble. So Far: There is a spark Fuel pump works All new fuel lines Freshly rebuilt carb Points cleaned and gapped Spark plug gapped and tested Engine turns over fine Engine has compression Engine will backfire every now and again when cranking Recent oil change Wont run with carb cleaner sprayed in carb Wont run with carb cleaned spayed in spark plug hole I think thats all I can remember for right now. Does anyone have some suggestions to try? Thanks! Bevan Share this post Link to post Share on other sites
B-8074 20 #2 Posted October 1, 2010 When you rebuilt the carb did you set the idle and main fuel jet needles? Turn them all the way in gently and back the idle needle out 1 turn and the main out 1 1/2 turns. I think thats right, if not I'm sure someone will correct me. Share this post Link to post Share on other sites
yokomist 0 #3 Posted October 1, 2010 Thanks for the reply B-8074, The kohler manual give two sets of info for setting the carb up. I tried both and neither helped. The carb is a walbro adjustable jet and the settings are listed as: Low 1 3/4 High 1 1/8 and just in case I tried setting listed under Kohler Adjustable Carb Low 2 1/2 High 2 But no luck under either setting. Thanks Bevan Share this post Link to post Share on other sites
Jim_M 179 #4 Posted October 1, 2010 Is your spark strong and blue? If it's not, it won't start the engine. If so, just for the heck of it, try a spark plug that's been proven to work in another engine. I have had new spark plugs that won't fire under compression, hot blue spark outside the engine but wouldn't run when installed. Share this post Link to post Share on other sites
B-8074 20 #5 Posted October 1, 2010 When you set the points did you make sure the crank was at TDC (top dead center)? Share this post Link to post Share on other sites
yokomist 0 #6 Posted October 1, 2010 I tried the plug out of my k301 which is good and new and that didnt help. When I set the points I turned the engine so they were at the most open position... I may have been incorrect doing that? The points are at .020 at the most open position. Thanks, Bevan Share this post Link to post Share on other sites
stevasaurus 23,454 #7 Posted October 1, 2010 Bevan...if it will not start with carb cleaner sprayed in the carb. Almost has to be no spark at the plug. Pull the plug, ground the threads of the plug to a bolt and with the coil wire on... crank the engine and see if you can see the spark jump. Be sure to use insulated pliers while holding the plug. If no spark...work your way back through the circuit with a multi-meter. After setting for so long, a few bucks on points plug and condenser is a good investment. Hopefully the coil is OK...they cost some bucks. :) Share this post Link to post Share on other sites
stevasaurus 23,454 #8 Posted October 1, 2010 Is your spark strong and blue? If it's not, it won't start the engine. If so, just for the heck of it, try a spark plug that's been proven to work in another engine. I have had new spark plugs that won't fire under compression, hot blue spark outside the engine but wouldn't run when installed. Jim...that is a new one...never heard of that. Any ideas on why that happened?? :) Share this post Link to post Share on other sites
yokomist 0 #9 Posted October 1, 2010 Hey Steve I have pulled the plug (done this with both plugs) And grounded it out on the engine block and seen both sparking. I agree that this seems like the weak link if it wont fire. I do have a condenser and coil off my k301 that were tried on this engine too. Hmmm there are too many possibilities, and its always knowledge that is my problem lol I appriciate the help! Bevan Share this post Link to post Share on other sites
stevasaurus 23,454 #10 Posted October 1, 2010 I'm stumped at this point. You did say you have compression, right. Share this post Link to post Share on other sites
Jim_M 179 #11 Posted October 1, 2010 What color is the spark? Steve, I have no idea. At this point I blame Chinese quality control. Share this post Link to post Share on other sites
B-8074 20 #12 Posted October 1, 2010 Try this. http://www.mywheelhorse.com/graphics/file/...ngineTiming.pdf Share this post Link to post Share on other sites
yokomist 0 #13 Posted October 1, 2010 Yes Sir, I have no way to measure it that I know of but there is definately good compression. Just to be 100% Jim I went ahead and tried the plug from my briggs engine and that didnt work either. I think that rules out the plug as far as i know. Spark is blue in color How wet should the spark plug be? I am not seeing it soaking or anything. Is it possible for there to be a blockage between the carb and the plug? When the engine was cranked initially, pieces of junk were coming out of the exhause hole. Bevan Share this post Link to post Share on other sites
B-8074 20 #14 Posted October 1, 2010 No need to call me sir, I work for a living to. I had the same problem once and I had thought I set the points right. It turned out that the timing was off. I set the points without checking to see if the "S" on the fly wheel was the sight hole. There is a post here somewhere that shows you how to do it with out a meter. :) Share this post Link to post Share on other sites
stevasaurus 23,454 #15 Posted October 1, 2010 Bevan...I hate to ask this...but you did have the choke open when you sprayed the carb cleaner in and the closed the choke about 2/3 and cranked...right??? The plug should be wet or at least moist if you are cranking and it is not firing. Still doesn't explain why it won't fire with carb cleaner sprayed in. :USA: Share this post Link to post Share on other sites
yokomist 0 #16 Posted October 1, 2010 Hey Guys, Steve - I sure did, I think I have tried about every position that stupid choke goes in from full open to full close lol I am trying to check the timing as per the link, hopefully it will sort me out. Just trying to find the sight hole in the shroud... any time now haha Thanks for all the effort! Bevan Share this post Link to post Share on other sites
stevasaurus 23,454 #17 Posted October 1, 2010 I see SOI in here...any ideas Chuck??? That post that B-8074 posted is excellent Bevan. Sometimes it is good to just sit back and have a beer and then go back to it. :USA: Share this post Link to post Share on other sites
B-8074 20 #18 Posted October 1, 2010 Not to sound dumb SOI??? Share this post Link to post Share on other sites
stevasaurus 23,454 #19 Posted October 1, 2010 Save Old Iron...one of the members that is very good with the electrical part of this. TT may have some ideas also. :USA: Share this post Link to post Share on other sites
B-8074 20 #20 Posted October 1, 2010 Ok, I've read alot of his Threads. Seems to know alittle bit about everything. Lots of good info. :USA: Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #21 Posted October 1, 2010 Try this: (with extreme caution) Take the air cleaner backing plate off of the carb, hold your hand over the carb throat, and crank the engine. Your hand should get sucked against the carb on each intake stroke. If it doesn't, you may have a partially stuck open valve (or a blockage in the exhaust) This "technique" has also been proven to get a stubborn carb primed. Share this post Link to post Share on other sites
Anglo Traction 761 #22 Posted October 1, 2010 I have pulled the plug (done this with both plugs) And grounded it out on the engine block and seen both sparking.. Hi Bevan, when you say Engine Block, have you checked it on the Cylinder Head. I assume you've not had the head off. You may have high resistance between Head and Cylinder. Just a thought ! Regards Share this post Link to post Share on other sites
stevasaurus 23,454 #23 Posted October 1, 2010 Beautiful TT...keep an eye on this thread...Bevan has been through some poop and deserves a break...thanks :) Share this post Link to post Share on other sites
yokomist 0 #24 Posted October 1, 2010 Anglo - Yes I am just a newb, I dont know the terminology lol I havent had the head off TT - thanks for your help, when my hand is over the carb there is sucking, but there is also some air expelled like a fast breathing in and out to match the cranking of the engine. Steve - TT is the man, he once gave one of my horses an identity, hopefully he will know what the deal is with this engine Also I am still searching for the flywheel shroud viewing hole. Any ideas? Thanks all! Bevan Share this post Link to post Share on other sites
B-8074 20 #25 Posted October 1, 2010 It should be on the left side of the shroud if your facing the fly wheel. Share this post Link to post Share on other sites
