jcb857 161 #1 Posted September 28, 2010 Do Pond tiller steer tractors and the Ride-Away Senior tractors have serial # plates on them and if so where should they be on the tractor. Thanks Share this post Link to post Share on other sites
evanloock 217 #2 Posted September 29, 2010 No they do not. The only way to narrow down the year on a Senior is to use the serial # off the Wisconsin engine. Not much use in doing that for a lever steer....they were only made in 1946-1947...but if you want a rough estimate on which year you can use the serial # off the Briggs or Wisconsin engine used on this model. You can find the serial # charts for the Briggs ZZP at http://www.asecc.com/ There is a list for Wisconsin serial #'s but I can't recall where they are located. Share this post Link to post Share on other sites
