galaxiejoe 0 #1 Posted September 27, 2010 I am having some trouble figuring out the model number for a WH just given to me. After going over some photos I think its a 1965-67,it has the black round choke and throttle knobs with the silver dash. it was repainted so most of the decals are missing and I can't id the engine. I was running like a top before it was moved but now it wont stay running for long. It looks like there was a new set of points installed but I think its not getting spark. Is there a cross reference for a new coil, condenser, and plug wire? Also what would the model number be for a plow or snow blower for this tractor Thank you for any help Joe Share this post Link to post Share on other sites
Docwheelhorse 2,875 #2 Posted September 27, 2010 Email sent.... Tony Share this post Link to post Share on other sites
rmaynard 16,866 #3 Posted September 27, 2010 :) Glad to have you aboard Joe. How about posting some pictures. That would be a good start. Lots of help and information will be available to you here. Bob Share this post Link to post Share on other sites
Suburban 550 28 #5 Posted September 27, 2010 :) Joe. Share this post Link to post Share on other sites
dclarke 4,117 #6 Posted September 27, 2010 :) Joe, glad you're here. Share this post Link to post Share on other sites
Kelly 1,037 #7 Posted September 27, 2010 Sorry but we need alot more info to help you out, post pictures if you are not sure of what you have, we can and will figure it out. Share this post Link to post Share on other sites
Roger from southern Iowa 1 #8 Posted September 27, 2010 :USA: Glad you found us!!! :) Share this post Link to post Share on other sites
whfan74 2,073 #10 Posted September 27, 2010 :) Once you get the picture posting figured out we will get you all squared away. Enjoy the forum! Share this post Link to post Share on other sites
racinfool40 203 #11 Posted September 27, 2010 :) Glad to have you with us. As I did check out the How to post picture's and you will get all the help you need!!!! Share this post Link to post Share on other sites
galaxiejoe 0 #13 Posted September 28, 2010 Thanks for the warm welcome, I could not get to my computer yesterday but here are some pictures. Joe Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #14 Posted September 28, 2010 :USA: That would be an 855 or 856. The ID tag under the dash housing is visible in the one picture, so all you need to do is "read" it to us. :) Share this post Link to post Share on other sites
wheelhorse656 20 #15 Posted September 28, 2010 :USA: hey glad to have you. P.S. i can id tag under the dash check it for your model number. :wh: Share this post Link to post Share on other sites
leichty 0 #16 Posted September 28, 2010 Welcome, nice to have you onboard. Share this post Link to post Share on other sites
galaxiejoe 0 #17 Posted September 29, 2010 The tag was half painted but I could make out 856, I don't think I would of seen that little tag there. so what type of Kohler engine would I have, I did find that tag but it only has the SN on it. The search engine will not look up 856, what model WH plow or snow blower should I be looking for. Also is there a source for tires mine are looking bad? Thank you Joe Share this post Link to post Share on other sites
Lane Ranger 11,788 #18 Posted September 29, 2010 That will be an 8 Horse Kohler starter/generator type motor. Also you can get a manual online on the Red Square website by chcking out Wheel Horse.org under Wheel Horse Tractors and Wheel Horse Links (the first link page on Red Square) and the First manual group should have the 855 Operating Manual and Parts List for your use. Share this post Link to post Share on other sites
Kelly 1,037 #19 Posted September 29, 2010 It may just be the angle but does the engine pulley (starter side) have two groves one being used to start it and a unused one?? if so it may be just a changed pulley OR it could be a 701 engine (7hp), but we would need the engine ID # to know that, and like I said it may just be my old tired eyes. Share this post Link to post Share on other sites
galaxiejoe 0 #20 Posted September 29, 2010 I joined the first yahoo group listed on wheelhorse.org, waiting to get approved. Kelly, your eyes are working well there are 2 groves on the engine pulley. The rear one is connected to the starter and the front one is unused, but has 2 notches cut in it. I was thinking it was for a rope pull start. Tomorrow I will get what numbers I can get off the number plate on the engine. I would like to get the correct belt cover for the starter after I get it running. Joe Share this post Link to post Share on other sites
Kelly 1,037 #21 Posted September 30, 2010 Well when you go to find a starter belt cover look for a single grove pulley to go with it, as the 701 double covers are hard to find and NOT cheap, find the numbers on the engine so you know or we can help you figure out what engine you have. Share this post Link to post Share on other sites
Kelly 1,037 #22 Posted September 30, 2010 couple more notes or questions is the gas tank plastic? should be metal, are you missing the points cover? and that almost looks like the thin air cleaner that was used on the 7hp engine the 8hp used a thicker one, how tall is the cover? engine ID tag should be under the coil, that is not mounted in the correct place but works and is fine. Share this post Link to post Share on other sites
wheelhorse656 20 #23 Posted September 30, 2010 i have a metal gas tank that is the right one if you are intereasted. Share this post Link to post Share on other sites
galaxiejoe 0 #24 Posted October 1, 2010 The only numbers that can be seen on the engine plate are First line 763570 and the line below 30160A. What is the second pulley on the fly wheel for? where should the ciol be mounted? The tank is plastic and I do have the points cover, I had it off to check there condition. Still can get the old WH running right. It will start run fine then the rpms will serge up and down a few times and die. I did notice that the spark from the points gets smaller as it starts serging. Plus its leaking oil from behind the fuel pump, the points cover, and the governor arm Joe Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #25 Posted October 1, 2010 A quick check of that spec number shows that the tag came from what I believe* to be a 1966/67 Toro Suburban tractor. Check to see if there's a printed (not stamped) letter "B" or "C" before the serial number. *Kohler claims that the engine was manufactured for Toro, and that's the only Toro I can find that used a K-181. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Spec numbers beginning with the number 3 were assigned to K-181 engines. Double belts from the starter/generator were used on some Kohler models to reduce belt slippage. (the 1961 701 was the only Wheel Horse to use the double belts) The coil would have mounted vertically to a bracket bolted to the "front" oil pan to block bolts. Share this post Link to post Share on other sites
