dw2 0 #1 Posted September 12, 2010 Hi. I am new to the 520 hydro and this site. Let me start out by saying you guys rock! I just aquired a 520 hydro, 1997 i think, and need some help. it will not back up. Sometimes it will creep a little, others not at all. I am going to change the fluid and filter since i dont know when that was done last. What next? Please use simple terms. Also, what kind of fluid for the trans? I am brand new at this. Thanks in advance. dw. Share this post Link to post Share on other sites
520HC 207 #2 Posted September 12, 2010 Are you aware you have to push down on Hydro lever and then pull back to go into reverse? Just a thought. Share this post Link to post Share on other sites
dw2 0 #3 Posted September 12, 2010 Yep. I've gotten that far. It either creeps or doesn't move once the lever is in reverse. Another question I thought of. Where is the drain for the hydro? Share this post Link to post Share on other sites
dw2 0 #4 Posted September 12, 2010 Just took the cam plate apart and found that the center bolt was all gumed up from years of mowing. Cleaned it out, backs up like new. Share this post Link to post Share on other sites
