sodbuster 1 #1 Posted August 30, 2010 I traded for a wheel horse lawn vac,looks complete.how does the drive belt hook up?? it came with a belt and I cannot figure out the route.the impeller has its own pulley. :) Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #2 Posted August 30, 2010 Did you happen to check for a model number tag? Maybe something like this one? Share this post Link to post Share on other sites
Jim_M 179 #3 Posted August 30, 2010 If it's one like TT posted, it's complicated to explain.You'll need the idler pulley that mounts to the rear running board support to keep the belt from rubbing the axle. You need to move the right hand running board out so you can get the belt on. It runs in the outside groove of the pto. If you've never mounted one before, you really need to read the instructions. I've got the manual for the earlier model that was used on the Chargers and Electros around here somewhere. If I can find it I'll scan it for you. You may be able to sweet talk TT into scanning his manual if you've got the later style. Post some pictures of what you have so we can see if you have everything you need. Also tell us what tractor you'll be mounting it on. Share this post Link to post Share on other sites
sodbuster 1 #4 Posted August 30, 2010 these numbers are on the impeller.mn#7 2611 8 serial # 981564 Share this post Link to post Share on other sites
Jim_M 179 #5 Posted August 30, 2010 That's a 1973. You need Manual # A-5302. I don't have it. It's available from Toro and I'll bet TT's manual would also work, it's a 1975, but I think that model number came out in 1974. Share this post Link to post Share on other sites
DMK855 15 #6 Posted August 30, 2010 I would be very interested in copies of the Manuals also. Mine does not have any tags on it, but looks just like the one in the classifieds!! Thanks, Dwayne Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #7 Posted August 31, 2010 All I have is the P.I. sheet pictured above. It's just a single sheet used to show potential buyers what the implement or attachment consists of. :) Share this post Link to post Share on other sites
Jim_M 179 #8 Posted August 31, 2010 You can buy the manual at Toro.com. It's probably going to be well worth the little bit they'll charge you for it. Share this post Link to post Share on other sites
sodbuster 1 #9 Posted September 2, 2010 anyone come up with some pictures yet?? the rear pulley lines up directly in line with the rear axle. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,008 #10 Posted September 2, 2010 You can download the manuals for the 7-2611 and 7-2612/7-2613 from the Files of http://groups.yahoo.com/group/wheelhorsetractormanuals5/ They right at the bottom of the list. Garry Share this post Link to post Share on other sites
