Countdown To Christmas!
evan4434
Forward Sweep front end on 416-8
evan4434
I have a 416-8 that I want to put a 520H forward sweep front end on. Do all I need to do is buy the axle, or do I need other parts to make it fit like spindles or tire rod ends?
dodge78
I beleive they were the only common tractor with 1 inch spindles, so you would need spindles and rims to match. The holes for the tie rods are 1/2 inch, so you would probably need those too.
refracman
To convert over to the swept axel you will need everything, rims/ tires, spindles, axel, tierods, and the part from the tierods to fan gear.
If your interested I have the complete setup, send me a pm or email.
wheel horse 1045
whats the purpose for doing that ?
SAM58
:) :USA:
yes why?,
I do know that the 520 H has a heavier front end....
The tie rod ends are a little weak on the 416...
TT
Fitting the 60" mower deck and/or a front end loader are two good reasons for the swap too.
RS member "Dual Wheels" (Norm) did the swap on his H, but I haven't seen him on here lately. :)
fireman
I put the entire forward swept front end setup on my C-81. Basically bolts right in. If you get the heavier steering box also, you will have to drill two extra holes. Does wonders for stability when you have a front end loader on.
Wheel Horse Fan
I will be doing this swap on my 416-8 very soon. I bought the axle, spindles, rims and tie rods. I also bought the gear reduction steering.
I am doing the swap because I am putting an FEL on as well.
SAM58
FOR ANYONE INTERESTED...
I SEEN A 520-H WITH A 60" MOWER DECK FOR SALE IN THE RICHMOND, KY AREA.
HAS 850 HOURS?
FULL GAUGE CLUSTER, CROME HUB CAPS,OWNER SAID IT WAS AROUND A 2000 MODEL, I LOOKED UP THE MODEL NUMBER AND IT IS A 1991.
HE IS ASKING $2400.00 520-H
