Countdown To Christmas!
Pollack Pete
What Spark Plugs???
Pollack Pete
Trying to get my D-160 with 16 horse Onan twin to run a little better.Pulled the plugs.It had one Autolite and one Champion installed.I looked in my old Champion book but couldn't find what the correct plug is.Any ideas anyone?I went to our local Advance Auto.The kid there looked at me like I was from Mars.Thanks for any info.
TT
The Autolite isn't by chance a #437, is it?
I think I remember that from my Gravely days. :)
WH Raider10
I think you should be good to go with two Champion H10C spark plugs.
TT
If you choose to use Champion plugs, the correct number for the B series Onan twins should be RH18Y
H10s are for the Kohler (non-KT) twins.
bowtieguy
Last year I bought a couple plugs for my O-twin at the local parts store....just checked the box and they are Autolite 105.....not to say that they are the correct plug but that is what Napa's book called for....(thanks for reminding me to change them!!!)
wh79d160
I use NGK B-6L gap .025. I'm not a champion fan. I couldn't find the # listed for champion in my manual.
TT
For a P series Onan? (a 106 is supposed to be the RS17YX equivalent)
linen beige
The D-160 with an Onan should be a B43G.
My "D" manual calls for Champion plug type H-8 (Wheel Horse part #201336) and a gap of .25".
Another thing to remember is the recommended point gap for this engine is .23" NOT .20". (cold timing of 25 deg. BTDC.
slufoot733
Anything but CHAMPIAN! I've had nothing but problems with them. Go with AC Delco, Autolite, or whatever.
linen beige
:) OOPS!
The plug gap should be .025 and the points .023.
It would take a whale of a coil to spark across a quarter inch plug gap! :USA:
