btrrg1969 11 #1 Posted August 27, 2010 I just swap'd out my 48" SD for a 42" RD , I now need a drive belt from the engine to the deck , can anyone tell me the size I need , I cant get to the toro dealer for awhile so I'll have to buy a cheapy from TSC or somewhere. Share this post Link to post Share on other sites
stoneman 10 #2 Posted August 27, 2010 http://www.mfgsupply.com/MowerBeltsToro.html you can try here to get your belt number. Do you know the model # of your deck? Once you know the right belt number, Napa or TSC or whoever can cross reference and get you a belt that should work. When you get a chance you should get an OEM belt, and keep the old one for a spare. You can also go to "Parts Suppliers" in the links section here. Pinned under "Wheel Horse Tractors" Share this post Link to post Share on other sites
TT-(Moderator) 1,128 #3 Posted August 27, 2010 In most cases, the 42" RD deck drive belt is 98" long X Share this post Link to post Share on other sites
btrrg1969 11 #4 Posted August 27, 2010 Thanks I'll try the 98, that give me a starting place and I bet your right. Im going to load the tractor and take it with me just in case.I'll let you know.thanks brandon Share this post Link to post Share on other sites
btrrg1969 11 #5 Posted August 27, 2010 TT , how does it feel to be right , 98" was perfect . I will get a toro belt , but I was in a pinch , Thanks for your help Brandon :USA: Share this post Link to post Share on other sites
TT-(Moderator) 1,128 #6 Posted August 27, 2010 TT , how does it feel to be right Pretty good - on the rare occasions it happens lately. I use a 42" RD on my 416 sometimes, and the 98" belt is correct for that combo. Share this post Link to post Share on other sites
tgranthamfd 28 #7 Posted August 31, 2010 A little late but, I just put 2 belts on a 42" RD deck that I rebuilt the spindles, and put new blades on. 1/2" x 89" for the blades if you ever need that, and as TT said 1/2" x 98" for the mule drive / P.T.O. Share this post Link to post Share on other sites
