flatlander 0 #1 Posted August 15, 2010 Transmission is locked up on my model 753 and the tractor won't move. Can anyone help with an idea and what's it going to take to fix the problem. And. where can I located a manuel?. Share this post Link to post Share on other sites
gwgdog66 23 #2 Posted August 15, 2010 I'm not sure which tranny is in the 753, I believe it is the 5025. This web site has all the service manuals. You will have to register to view them http://www.mywheelhorse.com/modules.php?na...=show_doc&id=37 Share this post Link to post Share on other sites
wallfish 17,597 #3 Posted August 15, 2010 I would guess that the shift forks are out of alignment. You can pull the shifter out of the trans and look inside the hole to see them. The forks should be aligned in the center for neutral. You can move them with a flat head screwdriver. Share this post Link to post Share on other sites
Coadster32 793 #4 Posted August 15, 2010 I echo Wallfish's idea. That's the first and easiest thing to do. When the shifter is out, use a screw driver to move the shift forks around. You're in neutral when they form a box (rectangle). It is perfectly ok to remove the shifter lever. Only a set screw holds it in. Good luck. Share this post Link to post Share on other sites
flatlander 0 #5 Posted August 15, 2010 Thanks to you all..I will give it a try. Share this post Link to post Share on other sites
rmaynard 15,964 #6 Posted August 15, 2010 Your shifter will come out by loosening or removing the set screw/dog that holds it in place. Then look down into the hole and neutral should look like this. Bob Share this post Link to post Share on other sites
JUSS10 250 #7 Posted August 16, 2010 we should pin (sticky?) this. it seems to come up at least once a month... i just get into a habit of whenever a tractor comes home check the shifter, if it feels loose, pull it, align the forks, put in an appropriate set screw, turn till tight, back off a touch then tighten the jam nut. Share this post Link to post Share on other sites
rmaynard 15,964 #8 Posted August 16, 2010 The pictures in my post above are from the "FAQ and Mechanical Tips" section. http://www.wheelhorseforum.com/index.php?showtopic=18232 Bob Share this post Link to post Share on other sites
