WH Raider 10 0 #1 Posted August 7, 2010 I am looking for peoples opinions on how to get my tractor ready for snowblowing in the winter i am looking to use it to snow blow for a few neighbors as well as mine and was looking for advice on how to keep it in top shape. Thanks, Dan B. :D Share this post Link to post Share on other sites
hoppy 0 #2 Posted August 7, 2010 shouldnt be much to it. put the blower on, chains, weight. also believe you should be changing oil for winter use. pretty sure original owners manual calls for that on my 856. maybe spray your blower with a alittle silicone spray or spam. shouldnt be much to it. Share this post Link to post Share on other sites
Shuboxlover 485 #3 Posted August 7, 2010 And get a cab unless you like looking like a snowman :thumbs: Share this post Link to post Share on other sites
GlenPettit 1,718 #4 Posted August 7, 2010 Clean the entire plow & inside chute, make the surfaces are very smooth and then spray it all with Silicone so the ice & water don't stick to it. Wax your entire tractor for the same reason. Try and get rid of any nicks & bends in the Auger (hammer on both sides of it, hit with one against the 2nd). Litho grease on the chain. Tight Cable, loose chute. For Winter, a 10w30 oil is better, consider a little 'dry gas' in the tank, the minimum. Tires are usually a firmer 20# psi, weight at the tires is a real help in plowing. If on a cement or dirt floor, have a thin piece of wood under each tire when storing. Many of us like a 'float' or trickle charger to keep the battery at 100%, especially up here in MI where it often hits below 0 Share this post Link to post Share on other sites
WH Raider 10 0 #5 Posted August 11, 2010 Thank you gentlemen, this winter season is gonna be a blast! Thanks, Dan B. :D Share this post Link to post Share on other sites
daemon2525 5 #6 Posted August 11, 2010 Get a new battery Share this post Link to post Share on other sites
