dandan111 66 #1 Posted August 5, 2010 I know nobody ever whants to talk about it,but how much should a set of wheel horse front and rear wheel weights be worth. I would like to put a set on my 654 and know they are both salty and hard to find. I understand the supply and demand concept but can we get a ball park value? thanks guys Share this post Link to post Share on other sites
JoeMonag 1 #2 Posted August 6, 2010 Two years ago I paid $ 67.00 on e-bay for a rusty set of 55lb ea. cast iron weights The guy was local so I could go and pick them up, so no shippping cost. The are now primed, painted Red and on my 310-8. So if you can get them local, you save on shipping charges, which can be as much as the cost of the weights. Joe in Norton, MA Share this post Link to post Share on other sites
wallfish 19,303 #3 Posted August 6, 2010 The fronts are harder to find and I've seen them go for over $125. I paid $100 for my rear weights. Still searching for fronts. I'm talking about the older cast WH weights with the lines in them. Share this post Link to post Share on other sites
Kelly 1,037 #4 Posted August 6, 2010 I have 3 sets of WH cast rears I paid $55 for one set off CL, I bought a tractor for $200 that had a set on it, and I bought a trailer load of stuff with a set and sold most of the stuff off so the weight are about free now, I have 2 sets of cast front weights one set I paid $40 for the other I paid $75 for, but I've seen rears bring $200 and fronts $150 check you local dealer they I beieve can still be bought new. Share this post Link to post Share on other sites
rickv1957 77 #5 Posted August 6, 2010 Factory wheel weights can be expensive at 200.00 for a complete set,Rick Share this post Link to post Share on other sites
Arndts small engine repair 0 #6 Posted August 6, 2010 Hi i paid over $100 for Factory wheel weights ! :D Share this post Link to post Share on other sites
hcminis 1,762 #7 Posted August 6, 2010 I paid $25.00 for a rear set of weights and chains. They are the plastic covered style but still work great. Center decal blew off when I washed them but have it and put new adhesive on them. Should be good to go. Share this post Link to post Share on other sites
GlenPettit 1,718 #8 Posted August 6, 2010 Steel Weights will run a full $1/pound or more, buying local saves the expensive shipping, and to find a pair on a junker tractor from a local person will probably give you the best deal. Liquid filled tires are much less expensive if you do it yourself, and Rim Guard is just under $1/#. The plastic you-fill-with-sand are available from Sears for about $40 pair, less used. Share this post Link to post Share on other sites
Audioshot 2 #9 Posted August 6, 2010 Yeah, water fill them like GlenJeri said. Just install a TR618a valve and fill the tires with water/anifreeze about 80%. Share this post Link to post Share on other sites
WHC-125 4 #10 Posted August 6, 2010 The fronts are harder to find and I've seen them go for over $125. I paid $100 for my rear weights. Still searching for fronts. I'm talking about the older cast WH weights with the lines in them. Hey John if your still interested I still have those wheel weights from the show :thumbs: Share this post Link to post Share on other sites
Arndts small engine repair 0 #11 Posted August 10, 2010 Hi i do have the 12" plastic covered style ones ! :D Share this post Link to post Share on other sites
