3406pack 0 #1 Posted August 2, 2010 Does anyone have any good straight on pics of the rear PTO pulleys and how they are set up? I saw a few pulleys @ TSC, some bearings, and my fab gears started turning. Pulley sizes would be helpful also. Thanks in advance. T Share this post Link to post Share on other sites
C-Series14 15 #2 Posted August 2, 2010 Got some at home. It is more complicated than you think! Do you have the PTO shaft yet? Will get back to ya after work. If you go to one of the parts diagram sites, you can look up part numbers and see what all is still available. Share this post Link to post Share on other sites
C-Series14 15 #3 Posted August 2, 2010 Go to sepw.com, lookup the parts diagram, use Toro Consumer, then model, and use 83231. It will show you the routing and all that is needed. It is mostly located on the bottom of the tranny... If you need more, just ask. Share this post Link to post Share on other sites
3406pack 0 #4 Posted August 3, 2010 Thank you very much. No I havent gotten the PTO shaft yet because it is different from a standard PTO. Thats why I need pics. They have the adapter shafts @ TSC and some are pretty long. Long enuff to hold 2 piilow block bearings and the pulleys fit nice and tight on the shaft. All that would be needed was a nice weld to stitch it all together. Share this post Link to post Share on other sites
3406pack 0 #5 Posted August 3, 2010 I tried what you said and it kept showing no such part? I went through all diagrams and still nothing on C-195. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #6 Posted August 3, 2010 Here - I did the leg work: Direct link Share this post Link to post Share on other sites
3406pack 0 #7 Posted August 3, 2010 Thanks TT but I just got it to pull up under attatchments. I got it saved now. Now I dont know the pulley sizes cause it dont specify. Once again thanks to TT and C-series for your help. Share this post Link to post Share on other sites
