jgun45879 203 #1 Posted July 31, 2010 Hi, Can anyone tell me for sure what Kohler engine I have by these numbers? Ser. No. 698818 Spec. No. 28626E. I'm guessing its a K-161, but I need to be sure. Also, is a K-161 crankshaft the same as a K-181 crankshaft? Thanks, Jim. Share this post Link to post Share on other sites
TT-(Moderator) 1,170 #2 Posted August 1, 2010 It's a K-161 - from either a 753 or 754 Wheel Horse. The K-181 crank has a longer stroke than a K-161 crank. Share this post Link to post Share on other sites
linen beige 16 #3 Posted August 4, 2010 It's a K-161 - from either a 753 or 754 Wheel Horse. The K-181 crank has a longer stroke than a K-161 crank. The 702 used that spec # as well. Does the serial # date it to '63 or '64? Share this post Link to post Share on other sites
TT-(Moderator) 1,170 #4 Posted August 4, 2010 Does the serial # date it to '63 or '64? That serial number is higher than the numbers on both of my 753 engines. The 754 supposedly used "left over" 753 engines, so there really shouldn't be much difference with their numbers. Share this post Link to post Share on other sites
linen beige 16 #5 Posted August 5, 2010 Does the serial # date it to '63 or '64? That serial number is higher than the numbers on both of my 753 engines. The 754 supposedly used "left over" 753 engines, so there really shouldn't be much difference with their numbers. :thumbs: Share this post Link to post Share on other sites
