jla1257 2 #1 Posted July 30, 2010 So I needed a quick way to add weight to my 1257 for doing some dirt work and wound up adding water to the tires. After filling the tubes with water and bringing them up to pressure each tire weighed 67.5 lbs. for a total wt. of 135 lbs. Happy with that I put the tires back on and hooked up my 10" Brinly plow. Well, I raised the plow, put it in third gear and throttled up. In a hurry to get to work I let off the clutch as I normally do. The results were not normal. The horse took off with its two front tires off the ground. The thing is my seat pan latch tends to come unlatched at times as it did this time. As the horse lurched forward, the unlatched seat pan with me on it came up and threw me backwards. As we, the horse and I, raced towards the road the only thing keeping me on the 1257 was the instep of my foot caught around the side PTO handle bracket. After about 10' the front tires returned to the ground followed by my other foot promptly hitting the break. I guess the added wheel weight worked!!! Share this post Link to post Share on other sites
jtmoyer 1 #2 Posted July 31, 2010 i found out the tiller makes a great wheelie bar on the 417-8, the kids love it. Share this post Link to post Share on other sites
buckeye 5 #3 Posted July 31, 2010 :thumbs: Be glad you didn't get hurt.... but that is funny.. Share this post Link to post Share on other sites
Roger from southern Iowa 1 #4 Posted July 31, 2010 Rides like that are fun.....when things work right. Share this post Link to post Share on other sites
tranders 0 #5 Posted July 31, 2010 Sounds like something I would do. :thumbs: Share this post Link to post Share on other sites
KC9KAS 4,745 #6 Posted August 3, 2010 Guess you better get some weight on the front now! If you live in a freezing climate, you will want to drain the water and add something to the tires that won't freeze. Tire fluid for weight has been discussed MANY time here on RS. Share this post Link to post Share on other sites
B-8074 20 #7 Posted August 4, 2010 My local tractor shop told me they use regular blue windsheild washer fluid. They say it won't freeze and won't damage the rim like antifreeze or liquid calcium will. And it weights the same as water. Share this post Link to post Share on other sites
