IthacaJeff 151 #1 Posted July 30, 2010 Hi folks; Out mowing today in my 416-8 and a squeak develops. It gets stronger and more persistent as I mow. I start playing around to try and identify it. Raise the deck, lower the deck, turn off the PTO, all forward gears. . . it still squeaks. It gets worse under driving load -- up a slope and during tight turns. Lessens when going down the slope. No squeak in neutral or clutch pressed in. No squeak in reverse. So then, I hit a rough patch in the ground (furrows from farming days). Normally I go slow here, but had it in 2-Hi and got jostled around a bit. THE SQUEAK GOES AWAY! (Or at least not noticeable under the engine noise.) 15 minutes later I can hear the faint squeak again, this time more noticeable when turning. Any clues? Thanks, Jeff in Ithaca Share this post Link to post Share on other sites
btrrg1969 11 #2 Posted July 30, 2010 your parking brake is not on is it ? :thumbs: Share this post Link to post Share on other sites
Kelly 1,033 #3 Posted July 30, 2010 Front wheel bearings?? jack it up and grease the snot out of them then check it again. Share this post Link to post Share on other sites
Shuboxlover 482 #4 Posted July 30, 2010 one of three..... pulley on mule, deck belt, or grease your needle bearings in your PTO bell of course these are all just guesses :thumbs: Share this post Link to post Share on other sites
rmaynard 16,573 #5 Posted July 30, 2010 A mouse under the seat? A would agree with Kelly to check the front bearings. Share this post Link to post Share on other sites
Kelly 1,033 #6 Posted July 30, 2010 I had it happen to me, that's why I said try greasing the front wheels, probably need it anyway Share this post Link to post Share on other sites
DoctorHfuhruhurr 137 #7 Posted July 30, 2010 Have you considered using a mechanics stethoscope? You can get a cheap one for $3.99 at Harbor Freight Tools. http://www.harborfreight.com/mechanics-ste...cope-41966.html If the sound is resonating through the entire frame the stethoscope may not be of much help but for the price it may be worth a try if it's really annoying you. Share this post Link to post Share on other sites
gwgdog66 23 #8 Posted July 30, 2010 My C-160 8 Speed was doing this also. It drove me nuts. It turned out to be where the clutch pedal hooks to the tractor. The vibration while mowing was causing a the squeek. There are no grease zerks on it. I took the collar off and sprayed some WD up in there and the squeek went away. My brothers 2005 GT Classic has greese zerks on his. This picture is of the brake pedal side just to the left of the idler pulley. Share this post Link to post Share on other sites
WH nut 553 #9 Posted July 30, 2010 Check the tensioner pulley on the main transmission drive belt Share this post Link to post Share on other sites
rmaynard 16,573 #10 Posted July 30, 2010 Have you considered using a mechanics stethoscope? A stethoscope is a great idea for when the tractor is stationary, but since the problem seems to occur only while in motion, I think it would be a little difficult to use safely. Bob Share this post Link to post Share on other sites
JimD 3,347 #11 Posted July 30, 2010 Hmm, a squeak you can't identify, had one like that once. Couldn't find it. Turns out it was anonymous. It still pops up now and then just to irritate me. :thumbs: Share this post Link to post Share on other sites
octfst 378 #12 Posted July 30, 2010 Mine was the hood where the hood latches. there was no seal. put new seal on dash. fixed it for me Share this post Link to post Share on other sites
IthacaJeff 151 #13 Posted July 30, 2010 Good suggestions, gents. It seems not to be the deck or front mule. But it may be worthwhile to grease the PTO bell and the front wheels, and fuss with the clutch tensioner pulley. I'll let ya' know how it turns out. Jeff in Ithaca Share this post Link to post Share on other sites
rickv1957 76 #14 Posted July 30, 2010 Deck wheels can also squeak,give them a little grease,Rick Share this post Link to post Share on other sites
buckrancher 2,695 #15 Posted July 30, 2010 I guess I'll stop by :thumbs: Share this post Link to post Share on other sites
DoctorHfuhruhurr 137 #16 Posted July 30, 2010 Have you considered using a mechanics stethoscope? Share this post Link to post Share on other sites
Don1977 605 #17 Posted July 30, 2010 Have you checked your rear hubs, they can slide over against to trans. housing. Share this post Link to post Share on other sites
Kelly 1,033 #18 Posted July 30, 2010 Do one thing at a time so you know what fixed it. Share this post Link to post Share on other sites
hodge 6 #19 Posted July 31, 2010 Deck wheels can also squeak,give them a little grease,Rick That's my persistant squeak. Grease them and it goes away, but because they aren't sealed, the grease works out and the dust/moisture works in, and it squeaks again. Share this post Link to post Share on other sites
DoctorHfuhruhurr 137 #20 Posted July 31, 2010 Harbor Freight ear protection on sale now for $2.49. Share this post Link to post Share on other sites
gwgdog66 23 #21 Posted August 1, 2010 Also check your transmission input shaft pulley and make sure the set screw is tight. Sometimes they back off athe the pulley can slight out and rub the belt guard. Share this post Link to post Share on other sites
IthacaJeff 151 #22 Posted August 1, 2010 Brian (BuckRancher, aka, stainless steel RJ) stopped by and we started looking at potential culprits. Keep in mind that the squeak had all but gone away. Deck wheels, steering assembly, clutch and brake pedals, deck wheels, and all the grease fittings. Found a small drive belt positioner (down by the PTO bell, part of the PTO friction plate brake) that seemed out of place and had fresh rub marks on it. Drove it around a bit, mowed some, and parked it. . . . But somehow the parking brake was partially engaged. Don't know why or for how long (I never use it, but my son who mowed last may have. . . ). But, it was sort of stuck partially engaged. Actually, easy to miss based on just looking a the parking lever. But, if it was a more engaged, and I hit a bump, it could have undone it a bit and lessened the squeak. Might explain why it did not squeak in reverse, but does not explain a few other things. Don't know if that was it, but I still feel kinda stoooopid. Jeff in Ithaca :thumbs: Share this post Link to post Share on other sites
gwgdog66 23 #23 Posted August 5, 2010 Brian (BuckRancher, aka, stainless steel RJ) stopped by and we started looking at potential culprits. Keep in mind that the squeak had all but gone away. Deck wheels, steering assembly, clutch and brake pedals, deck wheels, and all the grease fittings. Found a small drive belt positioner (down by the PTO bell, part of the PTO friction plate brake) that seemed out of place and had fresh rub marks on it. Drove it around a bit, mowed some, and parked it. . . . But somehow the parking brake was partially engaged. Don't know why or for how long (I never use it, but my son who mowed last may have. . . ). But, it was sort of stuck partially engaged. Actually, easy to miss based on just looking a the parking lever. But, if it was a more engaged, and I hit a bump, it could have undone it a bit and lessened the squeak. Might explain why it did not squeak in reverse, but does not explain a few other things. Don't know if that was it, but I still feel kinda stoooopid. Jeff in Ithaca Been there and done that too Share this post Link to post Share on other sites
